headunit install
Old Nov 5, 2006 | 12:32 PM
Adam2562's Avatar
Default headunit install
hey guys new here juts bought me a 93 Accord 4 door LX as my daily driver.... i am currectly installing a Jensen VM9510 headunit in it and have come to a roadblock... i've hooked up all the wiring.. except the dimmer which there is none and a parking brake wire that ur supposed to hookup to ur parking brake so u can only watch movies when the e-brake is up.. so didnt hook that up either.. but when i turn the car on.. nothing f'in happens... yet when i take the fuse out and put it back in.. it seems to start up and the fan gets going and the cuts off.... anyone have any suggestions or idea's? any of you audio guys?
Old Nov 5, 2006 | 02:29 PM
mnaines's Avatar
Default Re: headunit install (Adam2562)
First, take a continuity tester and see if the thing is getting power. If it is, then its an internal problem. If not, then you've probably hooked it up wrong.
Old Nov 5, 2006 | 05:08 PM
turboDerrick's Avatar
the parking brake wire needs to be grounded so the tv will work. know as far as the radio not working , u need a test light 2 check both power sources red and yellow wires. dimmer wire doesn't need to be hooked up. also make sure ground is good.
Old Nov 5, 2006 | 06:43 PM
Adam2562's Avatar
Default Re: headunit install (turboDerrick)
ya i ended up doing that.. it was the headunit malfunctioning
Old Nov 5, 2006 | 09:14 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboDerrick &raquo;</TD></TR><TR><TD CLASS="quote">the parking brake wire needs to be grounded so the tv will work. know as far as the radio not working , u need a test light 2 check both power sources red and yellow wires. dimmer wire doesn't need to be hooked up. also make sure ground is good.</TD></TR></TABLE>
there's different kind of parking brake sensor also, some you can just leave it out but some wouldn't run if it's not connected to soemthing.
Chitown Si
Dec 2, 2012 06:36 AM
Kasta_JayDeeEm
Audio / Security / Video
Aug 18, 2011 10:14 PM
Adam2562
Nov 7, 2006 02:58 PM
Integra_Nguyen
Sep 10, 2004 02:31 PM
tuphatt
Jan 16, 2002 10:40 PM
