f20b engine...
Old May 3, 2007 | 07:11 AM
oem_certified_accord's Avatar
Default f20b engine...
if switching from f22b2 to f20b, is there a need for a tranny switch as well? or can i just use my f22 tranny?
Old May 3, 2007 | 07:30 AM
BlkChryKord's Avatar
No need to switch unless your getting the manual tranny w/ your new engine.
Old May 3, 2007 | 11:19 AM
Default Re: (BlkChryKord)
naw my tranny is manual right now, no auto for me. so just buy the engine complete w/ the components and i'm good right....?
Old May 3, 2007 | 12:17 PM
Alpinestar03's Avatar
Your going to have to switch two pins on the ecu I belive. I think its 11a-7a but im not positive. Your also going to have to wire in a v-tec soleniod and presure sensor i belive since your f22 is non-vtec. If the motor is not USDM it will probally have a internal coil distributer, you have to switch teh distributer with a external coil. Its generally the same as a h22 swap into a f22b2 non- v-tec.
-Eric
Old May 11, 2007 | 12:00 PM
AlmostJDM's Avatar
Default Re: (Alpinestar03)
yea just swap 2 of the pins and you only have to wire in vtec the f20b's dont have vtec pressure sensors
mills7x
Apr 2, 2012 11:29 AM
Tight R
Jul 20, 2009 11:00 PM
Dukie432
Apr 22, 2009 03:24 PM
blkhatch92
Nov 29, 2005 11:04 AM
boosted_teg93
Oct 28, 2004 09:17 PM
