ECU Codes
Old Apr 29, 2007 | 03:19 PM
hkhaperey's Avatar
Default ECO Codes
Hi,
My car facing some unkown problem and I couldn't found the solution here are details.
During drives the engine light comes and right away engine shut down and the engine light stay on, after stop the car tried to start again but fail and the Engine Light stay on untill you remove the key from ignition.
I wait for couple of minutes untill the Engline lights goes off then can start the engine and after little drive again engine light comes on and engine shut off.
I tried to take the Engine Light codes but the engine lights stay on and no flashing but when my car shut down and engine light stay on then I tried to take the Engine Light Code the got this in flashing mode.
LONG.....SHORT...SHORT...SHORT...SHORT...SHORT then pause the same code repeating.
Is the flashing means 15 codes if so whats then meaning of this code.
I can't drive my car as keep the engine shut down during drive.
I look forward to hear from you guys soon,
John
Old Apr 29, 2007 | 05:40 PM
JohnD1079's Avatar
Default Re: ECO Codes (hkhaperey)
http://tech.hybridgarage.com/tech/codes.html
it says its the iacv. if thats what it is, check the connection there and clean the iacv with come carb cleaner.
Old Apr 30, 2007 | 07:15 AM
hondadude's Avatar
Ignition Output Signal
missing or defective ignition output signal
EKcivicEK
Jul 17, 2010 09:45 PM
xpoisnfreex
Dec 29, 2008 12:54 PM
roller
Jun 13, 2004 11:57 PM
EKtypeRhaTcH
May 2, 2003 08:03 PM
eg686
Apr 18, 2003 01:01 PM
