Code clearing question
Old Apr 27, 2007 | 10:20 AM
Acco12dv6's Avatar
Default Code clearing question
Hi,
My TBS and ABS lights are on and I went to Honda and got it scanned. They said it was a faulty/out of place Left rear abs sensor, so I ordered the new part from them. My question is, do I have to do this at Honda or can I do this at an outside shop, and does the lights go off on there own or needs to be cleared? Don't want to waste extra money bringing it back and forth.
Thanks!
Old Apr 27, 2007 | 11:02 AM
CB7 ghost's Avatar
Default Re: Code clearing question (Acco12dv6)
whoever does the work, ask them to clear the light for you.
Old Apr 27, 2007 | 10:15 PM
Acco12dv6's Avatar
Default Re: Code clearing question (CB7 ghost)
So the code needs to be cleared regardless if the part is replace or not?
Old Apr 28, 2007 | 06:21 AM
JimBlake's Avatar
If the problem isn't fixed, the code will just come right back.
After fixing it, the CEL will quit lighting up after a certain time, but the error code will still be stored to confuse you next time something breaks.
Old Apr 28, 2007 | 09:10 PM
lowered94accord's Avatar
Default Re: Code clearing question (JimBlake)
once you have it replaced whether its at honda or somewhere else you can reset your ecu yourself that way the code is not stored anymore. otherwise as jimblake said it will just come back on and it will be the same code and you will be highly confused!
mas21958
Honda CR-V & Element
Jun 13, 2019 07:41 AM
SlowDriver74
Oct 8, 2011 09:37 AM
fassassin
Jan 8, 2005 05:17 PM
LeonyneSirena
Apr 23, 2004 09:22 AM
