o2 sensor question
Old Sep 24, 2003 | 04:29 PM
ddua's Avatar
Default o2 sensor question
I just change my ATF then I notice the connector between O2 sensor wire and the
o2 sensor( the one at the end of the header and b4 the cat) is burned due to the
header ( I installed the DC sport header like a month ago).
The connector is made of plastic so it melted since it's touching the header
( to the shop that install the header) but the wire is fine
My CEL is not light up , question is : is it ok leaving the connector like that ?
and what happen usually if the O2 sensor at the header not working ?
Thx for the answer
Old Sep 24, 2003 | 05:07 PM
LookingForVTEC's Avatar
Default Re: o2 sensor question (ddua)
Depending on how badly melted the connector is I would replace it. At lease I would zip tie it out of the way. You could go to a junkyard splice in a new connector or you could just hard wire the o2 sensor around the melted connector. But I would only do that if the connector was badly destroyed.
MainStreamHonda
Aug 9, 2011 09:36 AM
orourkeusn
Honda Civic (2006 - 2015)
Jul 5, 2008 04:02 AM
mugenpovver
Feb 16, 2008 12:56 PM
newBcrxer
Jun 21, 2004 08:46 AM
ddua
Aug 28, 2003 08:15 AM
