diff between disc and drum brake
Old Sep 28, 2003 | 11:20 AM
ddua's Avatar
Default diff between disc and drum brake
any particular diff between them ?
I couldn't find on internet what kind of brake does my car use, anyone know ?
Old Sep 28, 2003 | 11:22 AM
Kavehman's Avatar
Default Re: diff between disc and drum brake (ddua)
discs used on front drums used on rear. Discs work a lot better
Old Sep 28, 2003 | 11:27 AM
ddua's Avatar
Default Re: diff between disc and drum brake (Kavehman)
So all sedan has that setup, disc on the front and drum on the rear ?
how about SUV ?
Old Sep 28, 2003 | 11:53 AM
Kavehman's Avatar
No not all sedans have that set up, ur car has that set up. Drums are a lot cheaper and older technology so their used to cut costs, and save money. Dedpends on the car really. Drums are starting to get phased out but you can still find them on many budget priced cars. i.e civcs and accords( i believe the 2003 models have a disc disc set up).
Old Sep 28, 2003 | 01:15 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">No not all sedans have that set up, ur car has that set up. Drums are a lot cheaper and older technology so their used to cut costs, and save money. Dedpends on the car really. Drums are starting to get phased out but you can still find them on many budget priced cars. i.e civcs and accords( i believe the 2003 models have a disc disc set up).</TD></TR></TABLE>
yeah, it's old technology but the only good thing it's cheap and the drum brake last much longer.
the drawback would be the heat, the closed design of the drum brake often give you a soft panel, which reduce the braking ability due to the heat trapped inside. you probably wont feel a sh-t driving normal but on the track and autoX, you might want four wheels disc brake.
disc brake is more and more common now, almost replacemnt the rear drum on newer vehicle. just like abs and airbag/srs(my 14 years old acura only got one airbag, which only offered to the driver )
Old Sep 28, 2003 | 04:51 PM
FatJoe's Avatar
Default Re: diff between disc and drum brake (iam7head)
i thought all special edition accords came with quad disc brakes? guess not...
Old Sep 28, 2003 | 09:58 PM
ddua's Avatar
Default Re: diff between disc and drum brake (H22Accord90DX)
I found that my car has all-disc brakes, not sure though coz the source is not very
reliable.
It is in here :http://www.accordracing.com/st...7.jpg
PS: It said the muffler of SE is dual tip but when I got the car it has single tip
muffler..........
Old Sep 28, 2003 | 10:19 PM
FatJoe's Avatar
woohoo i was right!
Old Sep 29, 2003 | 12:45 AM
Monkey Fing a Coconut's Avatar
the front brakes are disc, no question about that, then go look at the rear brakes, if they look like the front, theyre disc, if they dont, theyre drum....
mixmastabob
Aug 24, 2006 10:27 PM
HatchBox
34
Dec 5, 2004 12:09 PM
JjuuN R
Jan 20, 2004 08:00 AM
HT Chaplain
Aug 20, 2003 11:21 AM
JaeOne3345
19
Jul 10, 2002 09:07 PM
