brake problem
Old Nov 3, 2003 | 05:07 PM
nrusso14's Avatar
Default brake problem
Rotated my tires today and noticed that what I think is the heatshield behind my rotors (could be wrong. It was the thin metal piece directly behind the rotors) was bent to ****! My car does have a little bit of wobble to it when i step on the brakes, but I figured it was from the rotors. The only thing I can think of is that when stepping on my brakes and my rotors being warped, it may have bent that piece back, but not this bad. Any comments? Thanks in advance. (I'll try to get pictures of it if I get a chance.)
Old Nov 3, 2003 | 06:42 PM
jspark79's Avatar
Default Re: brake problem (nrusso14)
bro that dont sound good at all....then again I am not familiar with that
Old Nov 3, 2003 | 07:09 PM
SIMATIC's Avatar
Default Re: brake problem (jspark79)
i dont thtink that piece is anything much, but i do belive ur rotors are warped. good luck
Old Nov 3, 2003 | 09:18 PM
Nick H's Avatar
New User
Default Re: brake problem (SIMATIC)
whoever did your brakes last time probably bent it back for ease of instalation...that piece is just there to keep brake dust from getting into your bearings, balljoints, shocks etc....but your rotors may be warped...don't make the mistake of getting them turned...go ahead and get new ones along with pads as well!
Old Nov 4, 2003 | 01:25 AM
gaydm.accord's Avatar
nothing to worry about the shield was actually designed for airflow and other purpose but im familiar with it being for airflow so that your rotors gets some air to it this info was brought to you by.... "my auto tune up and emissions controler instructor". oh yea and another info just FYI ever sinc ei put my mugen replica front bumper (fiberglass) it extended the stock bumper so the air flow is now different and now when i apply the brakes i know that it gets real hot and i have a hard time breaking it slides so i need to find a better way of cooling my rotors... the rotors and brakes are new too im either going to upgrade or get some bendable tubing big enough and yatta yatta yatta sorry for jacking your thread
Old Nov 4, 2003 | 06:28 AM
nrusso14's Avatar
Default Re: (gaydm.accord)
I'll be buying new BREMBO rotors real soon. Anybody have suggestions on whether to buy drilled, slotted, or drilled and slotted? I've heard that slotted tears up your brake pads. Anybody have recommendations on good brake pads...AEM, etc.? Thanks again guys...these are great answers.
Old Nov 4, 2003 | 01:08 PM
theres a brake pad called green stuff expensive it works and it leaves close to no debree so your rims dont come out black and as for the rotors blanks should be fine for daily driven cross drilled is for racers but its known to crack and slotted is fine too i would go for the slotted people say that theres no difference between the blanks and the slotted but i think you get wha tyou pay for
Old Nov 5, 2003 | 05:25 AM
nrusso14's Avatar
I'll probably be getting slotted brembo rotors then. I've found them on ebay for pretty cheap brand new. Thanks again for the great answers.
Old Nov 5, 2003 | 09:46 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">nothing to worry about the shield was actually designed for airflow and other purpose but im familiar with it being for airflow so that your rotors gets some air to it this info was brought to you by.... "my auto tune up and emissions controler instructor". oh yea and another info just FYI ever sinc ei put my mugen replica front bumper (fiberglass) it extended the stock bumper so the air flow is now different and now when i apply the brakes i know that it gets real hot and i have a hard time breaking it slides so i need to find a better way of cooling my rotors... the rotors and brakes are new too im either going to upgrade or get some bendable tubing big enough and yatta yatta yatta sorry for jacking your thread</TD></TR></TABLE>
When you changed the rotors and pads, did you changed the fluid? If not, try that. The fluid plays a big part, bigger than most people would think.
Old Nov 5, 2003 | 10:04 AM
vabchaccord's Avatar
Default Re: (nrusso14)
Any idea where to get the Green stuff brake pads, or does anyone else have recommendations on pads that significantly reduce brake dust?
Old Nov 5, 2003 | 01:30 PM
touring accord
ill try that just to see if it improves good lookin out and the green stuff vabcaccord most aftermarket shops/performance shops should carry them they are expensive though
BucCivicSi99
Suspension & Brakes
Mar 26, 2009 11:08 AM
ajtaccord
Aug 13, 2007 03:09 PM
hometheaterman
Sep 25, 2005 07:00 PM
WiggiE
Jun 22, 2002 10:54 PM
EF_LSVtec
May 30, 2002 02:35 AM
