how do I replace gauges in dash?
I recently got reverse-glow gauges for my 98 and was wondering how i'm supposed to remove the window to get them on. anyone do this or know how? do i have to remove a good portion of my dash?
Re: how do I replace gauges in dash? (AKaccord)
go spend $20 on a chiltons or haynes manual for your model--it will aid you in what you need --be careful with the needles when removing
I've been tossing around the idea of replacing the gauges in my car (a '99 LX).
Do you have a link to a picture of how the reverse glow gauges look?
Thanks!
Thanks!
Simple, you have to take the dash off, take off the cruise button, rear defrost, Led light ****, any of those little things, just stick a screw driver in the bottom of it and it pops right out. there are clips you have to unscew behind them. after that you have to take out the stereo (deck) and there are 2 screws underneath the ac(heater) unit, unscrew that then the dash comes out pretty easily, you might have to tug it a bit, then unscrew and unclip all the wires from the cluster gauge (speedo, tach....) and then pull it out, then you can take off the window to put on the gauge.
Modified by rival12 at 3:50 PM 4/5/2004
Re: how do I replace gauges in dash? (Heat)
mrb18c
01-13-2004 05:10 AM
743power
10-26-2002 08:31 PM
