code 7 on a automatic trans
Old Mar 30, 2004 | 06:21 PM
alb_accord's Avatar
Default code 7 on a automatic trans
ok guys i get a code 7 on my automatic transmision. now someone told me is the selenoid and that is it. but what the hell is a selenoid. i don't know jack about transmisions. nothing nada njente. so can someone please tell me what is a selenoid and what does it look like and where is located and how do i fix this ************.
Old Mar 31, 2004 | 05:33 AM
Filthy Focker!'s Avatar
Default Re: code 7 on a automatic trans (alb_accord)
I think, unless i am mistaken that you are talking about the shift solenoid. You have not stated the year of your car, so the procedure to test may not be accurate.
If the solenoid is open, shorted or out of specifications, it needs to be replaced.
1. Use a DVOM to test the solenoid’s resistance. Measure terminal A and ground. Measure terminal be and ground. Should be around 14-16 ohms. if not, replace.
2. connect terminal 1 to postitive battery post. connect terminal 2 to postitive battery post. You should hear a clicking sound each time you make the connection. If not, then you may have a problem in the circuit.
3. check then for continuity from the A/T unit and ground. If there is continuity, replace solenoid.
I suggest getting a manual to check this out further because it is pretty difficult to explain a testing procedure without pictures.
Good luck
fs
Old Mar 31, 2004 | 06:25 AM
alb_accord's Avatar
i don't even know what a selenoid is. i don't know what it looks like. i checked the hayens manual but i didn't see it. maybe i am looking in the wrong place.
i have a 90 accord ex. automatic transmision. when the S light comes on i noticed that my automatic transimision shifts from 1st gear to the 3rd gear. i have to turn off the car and then turn it on so the automatic trans can shift from 1st gear to the 2nd one then to the 3rd one.
Old Mar 31, 2004 | 06:50 AM
Default Re: (alb_accord)
check here
http://www.honda.co.uk/owner/A....html
fs
Old Mar 31, 2004 | 08:41 AM
alb_accord's Avatar
**** i didn't find them on that site too.
Old Mar 31, 2004 | 08:56 AM
http://www.honda.co.uk/owner/A...1.pdf
Old Mar 31, 2004 | 11:28 AM
alb_accord's Avatar
**** can't see it too, ****
thirtycal
Honda Civic (2001 - 2005)
Jul 6, 2019 04:50 PM
nickeynick
17
Feb 2, 2011 11:02 AM
nihad
Aug 14, 2007 07:03 PM
ParinoidAndroidX
Feb 21, 2007 01:31 PM
