NEED ANSWER! 1997 Accord Harness, 1994 H22a motor
I have a 1997 OBD 2 accord whose harness i'm using for my motor swap. now the motor i have is a jdm 1994 h22a. While the vtec, knock sensor etc. is all fine and dandy but we are running into some problems with the crank trigger? is the 94 h22a supposed to come with it and be bolt/plug on? also since the accord harness is for an obd 2 accord ecu, will the JDm p13 plug right up or do i need to order an obd 2 > 1 conversion harness?
As we're finalizing the wiring please reply if you know what i'm talking about.
thats fine on the ecu side... but i gotta make the obd 2 harness work with the obd 1 distributor on the prelude... does anyone know where i can get a wiring diagram for the crank trigger on the obd 2's and the obd 1 distributos... or has anyone specifically done an obd 2 to obd 1 conversion on the accord with an h22a?
