O2 Sensor
Old Sep 30, 2004 | 04:14 PM
CrAzyGsR101's Avatar
Default O2 Sensor
Hey this question is for my friends 95 accord 4dr lx. He has had problems with the connection of his o2 sensor. He wants to know if anyone has a pic of how the wire leadds to the ecu. thanks!
Old Oct 7, 2004 | 09:30 PM
Default Re: O2 Sensor (CrAzyGsR101)
bump
Old Oct 8, 2004 | 05:47 AM
Mike813's Avatar
he wants to replace just a o2 sensor??? or is he replacing the whole wiring from o2 to ecu??? i dont know the pinouts, but i know the wires run from the exhaustmanifold/under the dizzycap/into firewall (i think im missing one more place) too early to think
Old Oct 8, 2004 | 07:23 AM
madd's Avatar
Default Re: O2 Sensor (Mike813)
im on my lunch break so i didnt have time to look at it in detail...if its wrong ill correct it when im home after work, but here are some ecu pinouts:
well i found something different
http://www.plxdevices.com/ECUD...5.pdf
according to that its D14
Old Oct 8, 2004 | 03:54 PM
KatyHonda's Avatar
On 94 Accord the O2 sensor output is white/red and input wire to O2 senosr is Grn/Blu. Wires lead from the first 4-pin connector to a large 14 pin connector on the pax side shock tower. I use this point to monitor O2 output by backprobing the connector w/ small wire.
If he's trying to wire a old O2 sensor connector to a new "universal" O2 sensor, the input and out put leads of the O2 sensor must be matched correctly to the old sensor or it won't work. I used a Chrysler 4-wire sensor that I had saved in my 90 Accord EX by rewiring and it's still running some 8 yrs now.
good luck
Acura_I-RS
Oct 4, 2003 11:32 AM
gtpilot
Dec 12, 2002 12:27 PM
slwazgsr
Oct 17, 2002 06:53 PM
