removing ignition switch
Old Oct 4, 2004 | 12:54 PM
92lxguy's Avatar
Default removing ignition switch
92 Accord LX. How do you remove the ignition switch to swap it out. I'm looking at the unit that has 2 bolts connecting it to the steering column but I cant see how to get it off!!!! Does anyone know what I need to do?
Old Oct 4, 2004 | 06:37 PM
KatyHonda's Avatar
Default Re: removing ignition switch (92lxguy)
See following link for information.
http://www.cybertrails.com/~be....html
good luck
Old Oct 4, 2004 | 07:14 PM
CWestAccord's Avatar
Default Re: removing ignition switch (KatyHonda)
there is two bolts on the top of the steering column with the heads of them rounded off. cut slots in the heads of them, to make the bolt into a flathead screw. turn counterclockwise, until the steering column drops. now slide in the new switch, and presto.
jdmjosh1
Mar 31, 2010 03:32 PM
sgwood
Aug 17, 2008 10:02 AM
jaghouse
Jun 15, 2007 12:28 PM
Wayne_Curr
Nov 15, 2006 12:51 PM
PrestonCRX
Apr 23, 2006 11:55 PM
