shift knob!!!!
Old Oct 3, 2004 | 10:21 PM
Accord2NR's Avatar
Default shift ****!!!!
this is dumb, i just got the accord 2 weeks ago, first time i drove it was yesturday. today i bought a new shift **** but i didnt know how to take off the shift ****, wen i ahd my gsr all i ahd to do was twist it off???? the car and year is in my sig. how do i get the damn thing off?!
Old Oct 4, 2004 | 12:44 AM
Accord2NR's Avatar
Default Re: shift ****!!!! (iLoVeMyF22)
bump!
Old Oct 4, 2004 | 12:59 AM
sj993's Avatar
Shuold be the same type of setup. Unscrew it by turning it counter-clockwise and then try pulling it off.
Old Oct 4, 2004 | 07:43 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: shift ****!!!! (sj993)
There are two tabs that hold the shift boot to the ****. You first have to unhook the boot from the **** by pulling one side (front or back) down from the **** then the other side should fall away from the ****. Once the boot is away from the **** then just twist the **** off like you did on your GSR. Put the new **** on in reverse of the removal. Except you won't be able to connect the boot to the **** unless you replace the boot as well.
The stock **** and boot is a combination deal. To have them work correctly you need both parts.
So if you wan the boot to go all the way up to the **** then your going to want to replace the boot as well.
Old Oct 4, 2004 | 10:25 AM
fw190bvi's Avatar
Default Re: shift ****!!!! (TouringAccord)
since your already messing with the center cousole, why not get a new shift lever....forbidden motorsports and pspec tuning both make excellent units (and their owner/creators are members of HT)....the pspec comes with a think *** leather boot and a S2k style aluminum ****.....
pfcle
Honda Civic (2006 - 2015)
May 17, 2007 08:55 PM
tnewhallSi
Mar 31, 2006 11:44 PM
Shinbo
Oct 8, 2004 01:27 PM
Ludester
Dec 30, 2002 04:06 PM
andrewasf77
Nov 10, 2002 11:50 AM
