Dash clock
Old Jan 18, 2006 | 06:27 AM
dodge-honda's Avatar
Default Dash clock
In my 99 my dash clock's light does not work any more. Is there a bulb to replace? It displays the time, but at night I cannot see it.
Old Jan 18, 2006 | 07:34 AM
Heat's Avatar
Default Re: Dash clock (dodge-honda)
From a thread from last September:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFAccord &raquo;</TD></TR><TR><TD CLASS="quote">
It's a relatively simple process, and the 6th gen accords are notorious for this bulb blowing out. I don't have pictures but I will give you a general process for replacing this. You WILL NOT have to remove the climate control panel, just the clock assembly itself.
1. Use a small flat-blade screw-driver to pry the clock/hazard button assembly out of the dash panel. Wrap the screw-driver in a papertowel, tape, or a cloth to avoid scratching the plastic. This usually works best if you pry from one side then the other.
2. There is a vertical connector for the hazard switch, and a horizontal connector for the clock. Disconnect both of these and remove the clock assembly.
3. I believe there is a plastic cover on the back of this assembly. Remove it using a phillips head screw-driver. There you will see the back of the plastic bulb holder.
4. Twist the bulb holder out of the socket and replace the bulb and holder with a new one purchased from a Honda dealership.
5. Installation is the reverse of removal.
I believe this bulb runs $1.47 from the dealer, which is way too much IMO. You could buy an LED bulb conversion from http://www.ledautomotive.com/ if this becomes a continuous problem. </TD></TR></TABLE>
Old Jan 18, 2006 | 08:25 AM
Default Re: Dash clock (Heat)
Thank you sounds easy.
I might go for the LED kit later.
Old Jan 18, 2006 | 12:17 PM
Heat's Avatar
Reading over those again, I just wanted to clarify how to remove the clock.
Take a look at step numbers 7 and 8 from these instructions:
http://www.handa-accessories.c...e.pdf
The back unclips relatively easily, don't force it. When I took mine out during when I was installing a trunk mounted CD changer, I broke the clock assembly on my '99 LX. Cost ~ $20 to replace.
Old Jan 18, 2006 | 05:30 PM
AFAccord's Avatar
Phew! Thanks Heat, I was afraid I'd have to dig up that link again. lol
scottinky
Jun 25, 2010 08:52 PM
sixfiveoh
Aug 8, 2009 10:43 PM
Jtantes87
Oct 16, 2007 10:24 AM
liketofry
Honda Civic (2006 - 2015)
Oct 13, 2006 08:08 AM
simplyrob
Aug 19, 2006 12:23 AM
