check engine light
Old Apr 20, 2006 | 07:19 PM
Lamole's Avatar
Default check engine light
ok im trying to run my turbocharge accord with the stock ECU, and i got a FMU 12:1(vortech), an external MSD pump, and an inside the tank walhbro pump. i got a missing link for the MAP sensor, and still the check engine light still on. WHY???. it was on before i installed the missing link, and i changed the oxygen sensor also. so i disconnected the battery cable and turn it off. However, when i turn the car on the check engine light comes back. WHY???
Old Apr 20, 2006 | 07:52 PM
ujhonda's Avatar
Default Re: check engine light (Lamole)
what year is your car ?
get a code reader or do the jumper trick and pull the code out, that will tell you whats wrong
check engine means = something not working or missing (so check engine)
Old Apr 20, 2006 | 08:00 PM
iam7head's Avatar
Default Re: check engine light (ujhonda)
hard code? soft code?
is all the vaccum lines routed correctly?
missing link installed backward?
and most important thing, what code are you throwing?
palmtree
Jan 28, 2013 12:06 PM
oilspot
Feb 24, 2009 10:16 AM
()0()Miklo
Oct 7, 2007 04:30 PM
importdude2000
Jul 17, 2004 12:53 PM
