A/C Problem & Question
Old Apr 23, 2006 | 05:03 PM
Ruskimafia's Avatar
Default A/C Problem & Question
i have a 00 accord v6. well as you guys know its almost summer. Well i went to check on my A/C and noticed it wasnt cooling about a week ago. So today i decided to get some Freon to suck into the comprosser. Well i went to auto zone and The guy goes your comprossor dont work Im like WTF it worked all summer and 4times in the winter.
What can i do before i put a hole in my wallet?
what can i check ?
And is it possible to do it yourself ?
Thanks
Old Apr 23, 2006 | 05:12 PM
YeuEmMaiMai's Avatar
Default Re: A/C Problem & Question (Ruskimafia)
does it cycle on and off or does it just stay off?
Old Apr 23, 2006 | 05:16 PM
Ruskimafia's Avatar
the guy said theres supposed to be a clicking noise when it turns on or w/e but there isnt. all it does is pull air from the outside when its on. Like if u drive it gets cooler but if the car is at idle t gets warm agian
Old Apr 23, 2006 | 05:24 PM
Default Re: (Ruskimafia)
forget what the guy said for a moment.....
Does the compressor cycle on and off? The easiest way to tell is sit in the car, start it up with the a/c off, turn on a/c and you should the engine labor a little when the compressor kicks in sort of like this
e=Engine running
C= A/C compressor turning on
eeeeeCCCCCeeeeeeCCCCCCeeeeeeCCCCCC
IF your compressor is cycling on and off, the the system is low and you need to get it checked out and repaired. After repairs are made, you need to test to see if it can hold a vaccum for at least 12 hrs. Once it can, recharge with approperiate amt of r143a.
Old Apr 23, 2006 | 06:04 PM
Ruskimafia's Avatar
I just tryed it and when the climate A/c on the engine hesitates and when off it loses idle like its about to stall out or shut down
Old Apr 23, 2006 | 06:10 PM
something else is wrong then and you need to get that fixed first..........
Old Apr 23, 2006 | 06:18 PM
Ruskimafia's Avatar
i dont mean like almost stalling u know like the engine changes its sound ! Like the ac turning on and when u turn it off it does it to. Hard to explain
Old Apr 23, 2006 | 06:27 PM
Idle should change smoothly when the A/C engages and disengages.
I bet your system is low on freon due to a leak and the most likely culprit is usually the condensor in the front of the car.........
Old Apr 23, 2006 | 06:30 PM
Ruskimafia's Avatar
Default Re: (YeuEmMaiMai)
you might be right but i filled it up with freon today and the level is fine according to the gauge on the freon hose it is at about 30 psi
Old Apr 23, 2006 | 06:32 PM
Ruskimafia's Avatar
I was also told to check the Fuses but since its 1030 right now i cant so ill do that first thing the am
Old Apr 24, 2006 | 04:09 PM
Ruskimafia's Avatar
it seems the relay dosnt turn on or make a clicking noise. where is it located in the car ?
Old Apr 24, 2006 | 06:05 PM
A/C relay should be in engine compartment
Old Apr 25, 2006 | 10:29 AM
Ruskimafia's Avatar
where is it exactly located thanks
YeuEmMaiMai your a lot off help thanks alot
Old Apr 25, 2006 | 03:27 PM
#2 in the picture
Old Apr 25, 2006 | 03:46 PM
Ruskimafia's Avatar
can yo utel lme wahat htat is i HAve no idea on wat to start looking for i see the # 2 bu idont understand what htat is and where its in the engine bay
Old Apr 28, 2006 | 07:06 PM
Ruskimafia's Avatar
??? Please help
Old Apr 28, 2006 | 07:11 PM
Ross 2.0's Avatar
In a Junkyard near you.
#2 is in your fuse box you should be able to find it by the label under the cover
Old Apr 29, 2006 | 08:25 PM
LookingForVTEC's Avatar
Before you start taking stuff apart check amount of refrigerant with a gauge. Your A/C compressor will lock up may not even cut on if it is low on refrigerant.
Old Apr 29, 2006 | 10:56 PM
HONCORD's Avatar
Default Re: (MooGoCow3)
Have the car running, look at your a/c compressor, see if you can see the clutch catch. You said the car changes idle, when a/c is on. Thats normal, seems like compressor is kicking on, or locking up. If you are out of 134a(freon) the compressor will kick on at least twice in 5 sec. It should at least once in 10 sec.
P.S. (look for tiny metal shavings around compressor clutch....thats not good at all)
Chem mogu tem pomogu.
Let us know
Old Apr 30, 2006 | 12:55 AM
accord-pro's Avatar
Default Re: (HONCORD)
[QUOTE=HONCORD. If you are out of 134a(freon) the compressor will kick on at least twice in 5 sec. It should at least once in 10 sec[/QUOTE]
yo amigo,, if you are out of freon the compressor WILL NOT kick on at all..
Old Apr 30, 2006 | 06:29 AM
Ruskimafia's Avatar
i stated earlier in my posts my car is filled with freon it also filled higher then normal on the gauge. and the clutch Does not turn on
Old Apr 30, 2006 | 07:28 AM
integraswtrde's Avatar
did you ever loosen any lines to release the old freon?if you did then you cannot do this procedure at home.you need to evacuate the system before charging.even if you think it's charged there's air in the system not all freon.
Old Apr 30, 2006 | 07:50 AM
Ruskimafia's Avatar
Nope i have never did that. Should i take it to honda to have it checked out ?
Old Apr 30, 2006 | 08:04 AM
if you decide to take it somewhere,shop around.make sure they will you warranty.
Old Apr 30, 2006 | 08:08 AM
Ruskimafia's Avatar
I just wanted to have it chekced out like a diagnostics on it
