Problem with cold starting
Old May 7, 2006 | 11:00 AM
Mike VR6's Avatar
Default Problem with cold starting
This is for a 97 Accord LX with 102k, but it also happens on my 99 Civic EX with 87k. Both cars have newer batteries (within the past year or so) and both cars have new spark plugs. The Civic even has new plug wires and a distributor cap/rotor.
The problem I am having is that the cars take a few seconds of cranking to start first thing in the morning. After that--they start perfectly. I would like to take care of this issue because I worry that it will progress into something worse. Plus, I think the cranking isn't good for the starter.
Any ideas? I was thinking something with the fuel system...
Old May 7, 2006 | 11:10 AM
Nick H's Avatar
New User
Default Re: Problem with cold starting (Mike VR6)
it may just be that you don't have sufficient fuel pressure after the car has been sitting for a while...next time, try turning the key to the on position (without starting it), hold down the accelerator to build up some fuel pressure, and then try to start it...if this cures your "issue", then I wouldn't really worry about it...
Old May 7, 2006 | 05:01 PM
hondadude's Avatar
Default Re: Problem with cold starting (Nick H)
Turn on the key and wait for the check engine light to go off, then crank the engine. Holding the gas pedal to the floor will not build higher fuel pressure when starting.
Old May 7, 2006 | 05:54 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: Problem with cold starting (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Turn on the key and wait for the check engine light to go off, then crank the engine. Holding the gas pedal to the floor will not build higher fuel pressure when starting.</TD></TR></TABLE>
Old May 9, 2006 | 08:21 AM
stock99's Avatar
This is what I do....it still happens [much more noticeable on the Civic]
Old May 10, 2006 | 04:42 AM
HondaWrench's Avatar
Default Re: Problem with cold starting (stock99)
Nick H is probably saying that you've probably lost fuel pressure in the morning. Usually the relief valve or the FP Regulator is allowing gas to leak back to the tank overnight. A fuel pressure test is a sure fire diagnose. But building up pressure using the ignition key is a simpler troubleshoot.
But I think they're just sticky injectors. Try Techron Fuel Injector cleaners, they can probably also clean out those dirty passage on the fuel regulators.
Reason for edit: Mispelling
Modified by HondaWrench at 6:07 AM 5/10/2006
Old May 10, 2006 | 08:50 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Holding the gas pedal to the floor will not build higher fuel pressure when starting.</TD></TR></TABLE>
Even worse... Holding the gas pedal all the way down to the floor will SHUT OFF the injectors. That's programmed into the ECU to allow you to clear a flooded engine.
Pwnmeister
Aug 2, 2011 12:41 PM
wabisabiaveda
Jun 11, 2011 07:08 AM
cbrracer91586
May 19, 2007 04:31 PM
bb608901
Feb 4, 2007 08:19 AM
highneo
Apr 3, 2006 10:05 PM
