95 Accord Legend 2 Piston Brake Upgrade
Old 05-07-2006, 09:03 PM
sinister2c's Avatar
Default 95 Accord Legend 2 Piston Brake Upgrade
Here are some pix from my recent Legend 2 Piston Upgrade. I got some 2-piston GS Caliper from the junkyard with 25T brackets from a 95-97 Accord V6. Painted the calipers gold to give them the mugen look. I used rotors from a 95-97 Accord V6 or wagon.
I had to buy new seals for the calipers...freaking $65 (dealer didn't even have them only one company makes it and its special order) for seals. I fucked up the old ones by soaking them in oil to clean them. Oil expands brake seals like a sponge.
While I was upgrading everything I got new stainless steel lines too.
Calipers with no pistons and painted
The Pistons.
Calipers with new $65 seals.
25T Accord V6 brackets.
Rotor and Hub pulled. (remove the four bolts and a slide hammer does the trick.)
Three hits on the slide hammer and off the hub and rotor came.
Stock 10" rotor next to the V6 11" rotor.
Perfect bolt on (no mods what so ever)
new rear rotors and SS lines.
Finished Product behind 19" Axis Se7ens
Old 05-07-2006, 09:28 PM
RiceRocketDave's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (sinister2c)
How much better do the brakes preform now?
Old 05-07-2006, 09:41 PM
momstaxi's Avatar
looks sweet
Old 05-08-2006, 03:52 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (RiceRocketDave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceRocketDave &raquo;</TD></TR><TR><TD CLASS="quote">How much better do the brakes preform now?</TD></TR></TABLE>
x2
What model Accord do you have? EX?
Old 05-08-2006, 04:32 AM
sinister2c's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (TouringAccord)
Pedal feels better now with the bigger caliper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
What model Accord do you have? EX?</TD></TR></TABLE>
EX with H22
Old 05-13-2006, 11:39 AM
pumafeet10's Avatar
i am kind of wondering where u got the slide hammer..it has an attachement that you can bolt it to the hub, where did u get that by chance i know i can get a slidehammer at auto stores but the part that bolts on i ahve never seen?!!!! please help i need to get my hubs off!!! anyone out there know
Old 05-13-2006, 02:55 PM
HONCORD's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (pumafeet10)
If you look closer in the picture with the slide hammer, he has a tool attached to it, which hooks up to the hub by the wheel studs. Hammer away!!! Pretty nice, ah? You can also buy one that you can use with the impact gun. It works basically the same only a lot faster. Try any parts stores, they should carry it.
By the way great brake set up. You inspired me in doing the same. Found all the parts (except rims). Its all in my thread V-6 front brakes on a '95 4cyl.
Catch ya leter guys.
Old 05-13-2006, 03:30 PM
pumafeet10's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (HONCORD)
ok i m wondering where can u get the tool that hooks up to the wheel studs i have not seen a tool like that with the slide hammers so was wonsdering where he got the extra tool? sorry i didn't make that point standout earlier. Thanks
Old 05-13-2006, 09:06 PM
HONCORD's Avatar
You can try AutoZone, they have all kind of cool tools. Just ask them for that specific one.
You can actualy make it yourself. Its pretty easy to fabricate. When you see that tool thing, you'll see what I'm talking about.
You bolt the hub-puller tool to the hub with lug nuts and then screw your slide hammer in the senter of it. Just like a bolt and a nut deal.
Old 05-13-2006, 09:08 PM
specbb6's Avatar
great job, loving the color!
Old 05-13-2006, 09:17 PM
HONCORD's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (specbb6)
Yeah I thought it was an awesome one too. Too bad i cant use the same on mine, I dont think it would match to mine. I'm going solid black
Old 05-13-2006, 09:44 PM
pumafeet10's Avatar
I actually went to autozone tonight and they have slide hammers but nothing liike what he has on the end. The threads don't match up to the puller. I found a few slide hammer puller with the hub attachment which was like $45 so its kind of pricey since the slide hammer at autozone was like 15 so what to do ?
Old 05-13-2006, 09:54 PM
HONCORD's Avatar
Hey you know that u can rent tools from AZ for no charge right? Get the slide hammer. Rent the hub tool. U can use a different tip for the slide hammer rite? Find one that would go straight trough the hole inside the hub tool, washer and nut it in the back. Bam, Bam, Yey!!!
Old 05-13-2006, 09:59 PM
pumafeet10's Avatar
yeah i tried to see if they had a anyhting that would work and they don't nothing to adapt to the hub that has thread that fit the slide hammer
Old 05-13-2006, 11:05 PM
HONCORD's Avatar
ima check it out for you, let you know 2moro.
Old 05-14-2006, 01:29 AM
pos_cd5's Avatar
wow, very nice ...what pads are you running? and since you effectively increased the brake torque significantly in the front, what have you done to increase the rear brake torque to maintain the balance of your braking system?
Old 05-14-2006, 06:40 AM
H-T Order of Merit
in reference to the slide hammer and the hub attachment tool... AutoZone does carry them both, atleast over here they do. I rented them both from there like 3 years ago. Maybe try going to a different AutoZone, I've found some AutoZone's don't have the same exact thing as the next.
Also, an alternative to the slide hammer would be a small sledge or heavy rubber mallet. Once you have the bearing unbolted from the knuckle, hit the rotor a few times from behind where the caliper goes. I've heard others talk about using this method and it working. Don't worry about the rotor face since you'll be replacing the rotor anyway.
Old 05-14-2006, 10:23 AM
pumafeet10's Avatar
thats what i was thinking about the slide hammer that the one that i checked wouldn't have it. nota big problem i can check the other, i guess i also wanted to get a nice one just to have just to have something with a little more umph, but never tried just hammering it like you said. i mean i did try to hammer it before but out of frustration hahaha. The plan was that i have a friend who was goingto give me his 30 ton hydraulic press to press out the hub from behind but i just wanted to not have to pay to have this done again and try to do it myself.
Old 05-14-2006, 12:10 PM
gianinline's Avatar
daaanm hommie... that sh** look tight !!!!!
What junkyard did you go to?!... did you see any other gs in that junkyard?
Old 05-14-2006, 12:43 PM
HONCORD's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (gianinline)
You can try the hammer parts, just remember anytime you try to remove the hub without specialty tool your bearing may come appart. Juat giving you heads up on that.
Old 05-14-2006, 12:47 PM
lowered94accord's Avatar
That setup will also bolt right up to a 94 accord ex with ABS right? cuz im definently looking into that now
Old 05-14-2006, 12:54 PM
gianinline's Avatar
so, what would be the special tool for this job?
Old 05-14-2006, 01:00 PM
HONCORD's Avatar
I'm not sure if you can buy it at any stores, my shop got one. I'll try to find a pic for you hold on.
Old 05-14-2006, 01:09 PM
HONCORD's Avatar
http://img190.imageshack.us/my...m.jpg
Old 05-14-2006, 01:10 PM
HONCORD's Avatar
You can also use an impact on it. That thing works sweet! No bearing problems either.
Quick Reply: 95 Accord Legend 2 Piston Brake Upgrade
