Timing Belt Shopping list. (Just wanna make sure)
Hey there guys! I am planning to do a timing belt change on my 01 Accord LX. Just wondering, what are the shopping list for this car?
-Timing Belt
-Balancer Belt
-Accesorry Belt (A/C and PS/Alternator)
I am not planning to replace my water pump. Please don't flame me on this or talk to me into changing it. Though I might. Just don't mention this. =D
Are those the 3 things to be replace? How about the seals (hard to replace?) and do I need to buy any retaining rings???
Torque wrench a must?
(I am going to buy timing belt and balancer belt a Honda Dealer)
-Timing Belt
-Balancer Belt
Re: (TheMuffinMan)
crank seal
cam seal
front balance shaft seal retainer kit
if you have the money replace the tensioners (i'm guessing you're 90k+) but they were like $60 & $70 for me and that was with company discount damn
cam seal
Re: (oem_certified_accord)
valve cover gasket set? had to ask why not the water pump. it's like taking a shower and wearing the same **** stained drawers after you get out the shower.
Re: (Jmumblez2001)
Do I really have to change all those Seals? I'm actually at 85K. So, might as well change it.
Is there a retaining ring inside the F23Ax??? I know 5th gen engine had a problem with that. Same goes for the F23?
BTW when you guys tighten bolts and stuff in the timing, did you guys use a torque wrench?
H-T Order of Merit
Re: (The-Kid)
yes, replace the seals. They are probably about $2 a piece and aren't hard to replace. I used a scratch awl, poked it through the face of the seal and pried it out. Then using a large socket like and axle nut socket I tapped the new seal into place.
You can hold off on the tensioners and see how they feel when you have it apart, the dealership told me they don't usually replace them unless need be. I usually change them just to be safe.
I won't say anything about the ***** ****
yes, I use a torque wrench on every bolt. A bit over the top, maybe, but I feel more comfortable knowing it's at the recommended spec.
I would also add a valve cover gasket and maybe eve a thermostat since the coolant will be drained. Both are pretty cheap.
AHHHHH!!!! NOOOO!!!!!! WATER PUMP! Thy shall not say another word. JK JK!!!
All righty, I will buy the seals just in case if they look crappy. Should be ok though... I will definitely buy the valve cover gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord »</TD></TR><TR><TD CLASS="quote">lol.. you said water pump
my bad Teh Kid, i tought you we're talking about your 5th Gen. i dont know squat about the f23a1 </TD></TR></TABLE>
It's cool. I usually use my 5th gen as an example a lot in HT. the 6th gen is my parents.
Cool thanks guys! I hope all goes smooth.
hometheaterman
06-04-2010 11:17 AM
