idle problem
Old Feb 6, 2008 | 02:03 PM
valiebowler's Avatar
Default idle problem
my 92 arrord lx auto idles from about 900 to about 1500rpms what is the problem???
we changed the coolant temp sensor, cleaned the IAC valve, but when we pull one of the vacuum hoses (#21) it fixes the idle prob but smoke starts rolling out of the exhaust??
What can i do to fix the idle?
Old Feb 6, 2008 | 03:45 PM
hondadude's Avatar
Default Re: idle problem (valiebowler)
be sure the coolant is full; block burped thru the 12mm bleed screw at the T-stat housing.
Then you can adjust the FITV
Old Feb 6, 2008 | 05:17 PM
Default Re: idle problem (hondadude)
we did adjust the HITV does it need to be tight or snug???
when we pulled the vacuum hose the surging idle stopped y is that?
integra15
Jun 23, 2010 02:30 PM
hondachris1994
Mar 3, 2006 06:49 AM
JFG Kevin
Feb 22, 2004 09:59 PM
TurboCRVTEC
Oct 9, 2002 05:38 AM
