timing belt walking off
What will cause a timing belt to walk of the cam gear. I put on new belt, water pump and tensioner all oem honda. Its a f22a1 what could be the problem
MM Gruppe B
Re: timing belt walking off
Misaligned tensioner or sprockets. Verify that the cam sprocket bolt is not loose. Is the crank sprocket all the way on? On the F22B1 if you are not paying attention the crank balancer sprocket can slide away from the crank timing sprocket.
belts not loose i can tell you that much. I got the washer on the inside (against oil pump) of the timing belt but not sure of one on the outside. I got balance shaft sproket on and its rubbing bad on my timing belt. I am not driving it.
This is how i have it, but the balance shaft sprocket is from a f22b1 and i have a f22a.
age_texas
06-04-2012 07:20 AM
yosuthnmasa
04-08-2008 07:29 AM
hitvtecgetloud09
03-21-2004 05:27 PM
