Need help with distributor and iacv wiring for a H22A4 into a 6th gen accord
im working on my friends 2001 accord with a h22a4 swap. the person that did it install the motor but didnt finish up the wiring. i did alot of wiring with obd1 obd2 b and d series motor but this one is wierd. i see that the stock accord distributor harness is a single 4 wire plug. the distributor on the motor is a 2 harness (1 harness has 4 wires the other has 2) the distributor has an external msd coil with a msd ignition box. just want to know how to wire up the distributor do i have to wire it straight to the ecu or is there another distributor i can use? i searched on ht and even google and theres hardly any info about this wiring issue.
Re: Need help with distributor and iacv wiring for a H22A4 into a 6th gen accord
also the iacv is not pluged in. i found a plug that is a 3 wire dont know if thats involved with the iacv
and what is this sensor? do i need it if im switch the ecu to a chipped p06?
thanks eddie but i found something better
http://www.6thgenaccord.com/forums/s...ad.php?t=27142
everybody thats looking for this info i found it so thank me later
talonturbotsi94
08-18-2007 05:23 PM
6th, 95, accord, box, conversion, disbuter, distributor, distributorh22a4, gen, generation, h22a4, iacv, ignition, type, wiring
