1991 Accord Code Problems
Old Jan 4, 2011 | 02:49 PM
RandomWhiteGuy's Avatar
Icon2 1991 Accord Code Problems
Hello all.
Before the rest, i'd like to say thank you all for the info.
I have been lurking this website for awhile and it has been very useful.
I have a 5-speed 91 Accord with 272,XXX miles. (It runs amazingly well despite the below)
As for my problem/s...
I bought this thing ($700) about two weeks ago.
It doesn't rev over 3400 RPM in gear or in neutral.
It's throwing two codes: #8 TDC code and #15 Ignition Output Signal.
It also usually takes on average between 4-5 seconds to start the thing which seems longer than normal
It doesn't really hinder my driving as I usually have enough pull for everyday traffic.
Aside from an axle that needs replaced in a few months, a master cylinder that is going out and the seals shrinking some in the winter that is all.
Where do I go from here?
I believe it is in what i've heard called "limp mode".
Old Jan 4, 2011 | 02:53 PM
redbull-1's Avatar
Default Re: 1991 Accord Code Problems
You probably need a new distributor. If it was only code 15, then you could just replace the igniter inside the distributor; but, with the two codes, it seems more than that.
Old Jan 4, 2011 | 03:04 PM
Thanks Redbull.
In case this isn't it how would I test to see if my distributor is bad?
Old Jan 4, 2011 | 03:18 PM
redbull-1's Avatar
Both codes are related to the distributor. Code 8 is for the TDC sensor inside the distributor, Code 15 is for the igniter inside the distributor or wiring.
Some of the info. is at this link:
http://techauto.awardspace.com/ignition.html
Old Jan 4, 2011 | 03:26 PM
Thank you tremendously.
I will never go to an AutoZone again where the majority of vehicles on the road in the area are lifted trucks.
He told me that my car didn't have a TDC sensor. I wanted to smack him right there.
**** backwoods towns.
Old Jan 5, 2011 | 04:36 PM
Hey now.
I attempted to replace the distributor but I can't get the rotor button off. There is no screw on the flat part of the cylinder. I can't pull it off.
Help!
Old Jan 5, 2011 | 04:52 PM
redbull-1's Avatar
If you are replacing the whole distributor, there is no need to remove the rotor. The distributor is held on with three hold-down bolts.
Btw: Some of the 4th gen Accords with carburetors had a rotor retaining screw. I believe some of the 4th gen Accord with fuel injection did not. If there is no retaining screw, use a screwdriver and gently pry it off.
Old Jan 6, 2011 | 08:50 AM
The distributor i bought didn't come with a rotor.
I was hesitant on pulling it off as it is a tight fit.
I will try again.
Old Jan 6, 2011 | 09:30 AM
It worked! It took all of 20 minutes. I can hit the normal rev limiter now!
Redbull, you're my savior.
Now on to replacing the master cylinder...
GnatBee
Sep 1, 2012 11:04 AM
ADAMnQuickRDX
May 7, 2009 11:30 AM
PrecisionH23a
Jun 7, 2007 11:19 AM
EJ ITO
Feb 28, 2007 05:56 AM
VTC_CiViC
Feb 25, 2005 11:34 AM
