P1361, TDC intermittent signal fault
Old 09-19-2013, 12:01 PM
jamieb159's Avatar
Icon2 P1361, TDC intermittent signal fault
Hi,
I'm currently experiencing an issue with my 2000 Accord Type R.
If I go over 4000RPM the engine goes into limp mode and wont allow me over 3000RPM.
I have read the code using a wifi obd2 adapter. It was showing the error P1361, TDC intermittent signal error.
I was led to believe this was down to the crankshaft sensor within the distributor. I have now replaced the distributor cleared the EML but I still have the same problem. I have checked the sensor for any short circuit faults and all seems to be fine.
I disconnected the battery and tried an ECU reset but this made no difference.
Has anyone else experienced this and have a potential solution?
Thank you,
Jamie
Old 09-19-2013, 12:28 PM
Joyboy's Avatar
Default Re: P1361, TDC intermittent signal fault
Is it an H22 motor? If so should be behind Crank Pulley CKP/TDC combined
File Type: pdf
Old 09-19-2013, 09:40 PM
jamieb159's Avatar
Yeah it is mate, cheers. I'll have a look at that tonight. Had my cam belt done recently and found the idiots at the garage had cross threaded the bolt on the aux pulley. Possibly done some damage when the pulley came loose.
Cheers!
Old 09-19-2013, 10:38 PM
holmesnmanny's Avatar
it could just be unplugged or not fully plugged in
jersut
05-25-2019 05:07 PM
jamieb159
09-19-2013 12:02 PM
corey.treat
12-17-2012 08:54 AM
KURUPTinc
10-28-2005 10:17 AM
YellowR2000x2
03-04-2005 04:29 PM
Quick Reply: P1361, TDC intermittent signal fault
