Compression Ratio?
Old Jul 21, 2003 | 09:44 PM
aaaallll04's Avatar
Default Compression Ratio?
Ok so i want my car to go a little faster. Could i change the compression ratio? Kinda like the h22? Isnt the h22 the same as a civic, but with different ratio? Please let me know if i am making any sense. Thanks
Old Jul 21, 2003 | 10:46 PM
CD8's Avatar
CD8
Default Re: Compression Ratio? (aaaallll04)
no, i dont understand. the h22 just like a civic?
yes raising the compression ratio will increase hp, but only when you increase air,fuel and spark accordingly.
Old Jul 22, 2003 | 08:35 AM
aaaallll04's Avatar
Default Re: Compression Ratio? (CD8)
But by how may hp? And how do i go about changing the compression (steps and pricing for parts? How much does it cost? And most of all, is it worth it, or unsafe and usless?
Old Jul 22, 2003 | 09:16 AM
fluxion's Avatar
amin n'rangwa edanea
it's a fairly safe way to get a few extra horses for a n/a engine, just make sure there's adequate fuel delivery and it's tuned properly. not sure what the average gains are but 9.5:1 will properly be like 10-15hp, 11:1 maybe 20-25hp. i'm just guessing here, but call the place you plan on getting your pistons from and they'll usually have some pretty good answers for you.
Old Jul 22, 2003 | 04:53 PM
RABBIT9's Avatar
Default Re: Compression Ratio? (fluxion)
http://www.raceeng.com - Crower billet rods and Wiseco 11:1 pistons for the F-series.
Definitely worth it.
Old Jul 22, 2003 | 05:32 PM
aaaallll04's Avatar
Default Re: Compression Ratio? (RABBIT9)
yeahhhh, that url doesnt work. but can anyone else give me more info on how it all works and average price? And its "fairly" safe? hmm let me know about that too.
Old Jul 22, 2003 | 07:20 PM
Kidd_Stylez's Avatar
here is a little info that you might find helpful
https://honda-tech.com/zerothread?id=180883
Old Jul 22, 2003 | 07:52 PM
NathanMorris's Avatar
Default Re: Compression Ratio? (Kidd_Stylez)
CR affects fuel prices, emissions, as well as costs a ton of money to increase, any more than small amounts anyway.
CR is one of the last resorts I use to make power in the engines we build at the shop....of course this depends on the application as well....the above mentioned articles are rather good.
Old Jul 22, 2003 | 07:57 PM
RABBIT9's Avatar
Hey aaaallll04, the link is for Race Engineering; don't know why it's not working. Any way, they have a package that includes the Crower billet rods and Wiseco 11:1 pistons that runs about $1100. The pistons are for the stock bore F-series. I'm running them in my F22B2, and can highly recommend the upgrade; absolutely no problems. It's a completely safe upgrade, but fairly intensive. I'd only do it during a complete rebuild. Make sure that you have the basic bolt-ons (I/H/E), as well as some head work and the cam to take advantage of the higher CR.
Old Jul 22, 2003 | 08:44 PM
aaaallll04's Avatar
oh **** it, im just trying to go around spending the money to get turbo... but its so expensive for turbo, but so worth it at the same time.
Old Jul 23, 2003 | 01:01 PM
D114's Avatar
couldnt you shave the head or deck a little bit... and use those paper thin head gaskets to raise it up a bit? get those adjustable cam gears so you don't affect timing....
I would suspect that people would want to lower their CR if they installed a turbo, to something in the area of 7:1? I see people put turbos on their H series engines... and I know they run higher amounts of compression than the F series... Is that safe on stock internals?
Old Jul 23, 2003 | 01:46 PM
CD8's Avatar
CD8
Default Re: Compression Ratio? (D114)
i know a shop running 14psi of boost on a stock internalled h22... its put 370 somthing to the ground...
vtec95
Jan 12, 2005 04:03 PM
93H22ACX
Aug 25, 2004 02:20 AM
jdmcivicferio
Jun 2, 2003 01:14 PM
