reseting ecu
reseting ecu
sup guys, recently replaced my o2 sensors on my 98 accord. i unpluged the battery for a few min, does that reset the ecu? if not how do i do so? thanks
Re: reseting ecu (SIMATIC)
yes, that should do it or you could just remove the back-up fuse from the fuse/relay located in the engine compartment for at least 10 seconds.
yea just disconnect the battery for a few minutes...hook it back up and then start the car and let it idle for a couple minutes...don't hit the accelerator! just let it idle...
Former Sponsor
Re: reseting ecu (momstaxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi »</TD></TR><TR><TD CLASS="quote">yes, that should do it or you could just remove the back-up fuse from the fuse/relay located in the engine compartment for at least 10 seconds.</TD></TR></TABLE>
Yup either or works, but I prefer removing the fuse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi »</TD></TR><TR><TD CLASS="quote">yes, that should do it or you could just remove the back-up fuse from the fuse/relay located in the engine compartment for at least 10 seconds.</TD></TR></TABLE>Yeah, but on a '98 Accord that fuse isn't in the engine compartment. Open the right-front door, there's a fusebox in the end of the dashboard, near the door hinge. It's #13 in there.
Former Sponsor
Re: reseting ecu (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">Yeah, but on a '98 Accord that fuse isn't in the engine compartment. Open the right-front door, there's a fusebox in the end of the dashboard, near the door hinge. It's #13 in there.
Very true.
Very true.
