check engine
Old Mar 25, 2005 | 02:10 PM
galeano's Avatar
Default check engine
i have magnoflow cat and my check engine lite keeps coming on. got it look look at. mechanic said there is to much flow going into and the computer doesnt know how to read it. what ever he meant by that. what should i do wit. i also have a 21/4 piping exhaust done to it. should i replace the hole thing or what
Old Mar 25, 2005 | 11:13 PM
iam7head's Avatar
Default Re: check engine (galeano)
find out what code does it throw first, it's most likey is a cel for your new cat.
obd2 honda are known to be picky on aftermarket cat, with straight/test pipe you have no change of getting it away, even some of the performance cat will not do the trick for the ecu.
but i do know randomtech's cat will not throw a code but i not sure if you want to spend some more cash or not.
Old Mar 26, 2005 | 05:32 AM
SuperSlow's Avatar
if it is your cat tripping a code, just get a dummy plug to trick the computer.
GrantFuentes
Engine Management and Tuning
Sep 17, 2013 04:23 PM
otisblkr1
Dec 4, 2012 05:58 PM
jc007i
Jan 23, 2012 12:29 AM
ryu12341
Oct 12, 2002 09:16 PM
R-Rated
May 20, 2002 11:48 AM
