maintainence
maintainence
A close friend of mine has an Accord that is just a pointA to Point B car. Its a 94 Honda Accord LX with 130k+ miles on it. She bought it used and I'm pretty sure it was kind of neglected by previous owners. I've had the timing belt and water pump changed, put in new oil and filter and had the fluids topped off. My question is:
The next service I'm gonna do is flush the fluids. In addition to the transmission and radiator fluid flush, what else do I need to do?
Is there any other maintainence stuff I can do to keep the car running well?
Thanks.
Thanks.
Re: maintainence (skiptomylou)
plugs NGK . wires Honda factory, fuel filter, pcv valve, injectors service, air filter, tranny fluid,brake fluid flush, valve adjustment, cap, rotor, if you just hat the timing belt and water pump done recently , the coolant should be new,,
Re: maintainence (Honda-Master)
IM not sure about a 94, But I know HOnda upped the emissions warranty to 150,000 miles. They will replace your cap and rotor, spark plugs, wires, oil and filter. Also, and cat problems or exhaust , and o2 sensors are covered. You might call and check to see if your car is covered! Hope I helped some!!
Re: maintainence (Ashland02)
my cap, rotor and wires have 143K on them. I might replace the cap and rotor this year but they still look good and the car gets 32+ MPG
dman81
03-09-2005 01:51 PM
newhondaowner29
08-30-2004 09:33 AM
