Shaking wheels
Old Mar 17, 2006 | 12:14 PM
NAmodified's Avatar
Default Shaking wheels
Ive changed my front wheel hubs and bearings about 3 times and my wheels still shake. What do u thinkit could be? O and i was running a wrx and hit two sick *** dips going about 90-100.
Old Mar 17, 2006 | 12:22 PM
iam7head's Avatar
Default Re: Shaking wheels (pur3pimpin)
nice, tie rod could be bent, wheel could be bend, wheel could be out of balance.
Old Mar 17, 2006 | 01:07 PM
P_Adams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pur3pimpin &raquo;</TD></TR><TR><TD CLASS="quote">Ive changed my front wheel hubs and bearings about 3 times and my wheels still shake. What do u thinkit could be? O and i was running a wrx and hit two sick *** dips going about 90-100.</TD></TR></TABLE>
To iam7head's suggestion I would also add Broken Tire Belt. I don't know the road conditions in Unknown, California; but if you deal with potholes and incorrectly patched construction work - it's a good possibility.
You can quickly get a handle on the question of Tires/Wheels or Suspension by doing nothing more that rotating your tires front-to-back. If the shake diminishes and moves to the rear; suspect the tires/rims now mounted in the rear.
P
Old Mar 17, 2006 | 01:16 PM
NAmodified's Avatar
just a little shaky when im driving, but when i jack up the car and i its like im gonna take off the wheels, they shake a hell of alot. And I know it has to do with the bearing because the axle moves with it.
Old Mar 17, 2006 | 01:23 PM
P_Adams's Avatar
You very well could have a bent axle or a binding CV Joint. As it rotates slowly, there should be no run-out at all (it shouldn't wobble at all.)
I've seen instances where tow truck operators hook to the axles to tie the car down while towing.
Pull hard enough, and I've seen bent axles, bent rear control arms etc.
P
Old Mar 17, 2006 | 11:51 PM
Honda-Master's Avatar
try this see if it helps
http://www.ozaccord.com/forums/showthread.php?t=61
miggy23
17
Mar 7, 2010 06:37 PM
EdoMoto
17
Jul 12, 2008 04:41 PM
SikofFalln
Apr 16, 2007 05:53 AM
VWkila
22
May 13, 2005 02:59 PM
Thirty-Nine
Mar 30, 2005 09:06 PM
