Problem with Pinging (PLEASE READ)
Old May 3, 2006 | 03:50 PM
HondaGus's Avatar
Default Problem with Pinging (PLEASE READ)
Okay, well i have a 2002 Honda accord coupe,
anyway long story short, my original motor spun a bearing and cracked the cam so i replace the motor to a F23A1 NON ULEV motor, since i got the car is was late march, since then i never USED the AC, everytime i put the AC on the car Starts to ping underload HIGH RPMS 4,000 to shift (AUTO)...
i don't know if anyone notice this when you put Ur ac on at a red light the RPMS jump up... well my car does that and when i shut it off at a red light i STILL see the RPMS jump up from 500 to 700, then when the car starts to idle at 500 i hear that click 700, and it will ping,
now i took the batter off the car for 5 min and put it back on and the car doesn't ping AT ALL, as soon as i put the ac on the problem comes back....i have tried this for 2 weeks and it WONT ping till i put the AC on... anyone know what the problem could be? EASY FIX? is my COMPUTER MESSED UP? please HELP.
Old May 3, 2006 | 06:03 PM
Ross 2.0's Avatar
In a Junkyard near you.
are you sure it's not your compressor making the noise?
Old May 3, 2006 | 06:11 PM
HondaGus's Avatar
Default Re: (MooGoCow3)
but why would it still be clicking when its off and making the idle rev up? and then all of a sudden the car pings
Old May 3, 2006 | 06:48 PM
Ross 2.0's Avatar
I don't know. The compressor isn't harly enough load to make an engine ping.
Are you saying the compressor is clicking on and off while the a/c isn't on?
ujhonda's Avatar
Default Re: (HondaGus)
Many things can make your engine ping; but your AC / Ping question:
Check compressor clutch relay <– in your case I suspect this
Check condenser fan relay
Check also radiator fan relay
Remove your AC Belt and rotating the pulley by hand and feel bearing play and drag
Check your AC clutch pressure plate – Overhaul it if you can
Check your compressor clutch coil
Also check your EGR valve – and vacuum
Check engine even warning bulb OFF
Old May 3, 2006 | 07:04 PM
Chiovnidca's Avatar
Default Re: (ujhonda)
Ping or heat sheild rattle?
Old May 4, 2006 | 05:12 PM
HondaGus's Avatar
TTTT
Old May 4, 2006 | 05:13 PM
i_kick_turtles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGus &raquo;</TD></TR><TR><TD CLASS="quote">TTTT</TD></TR></TABLE>
I'm not sure why you're bumping this thread. They gave you some good advice, did you check it out?
Old May 4, 2006 | 05:43 PM
ujhonda's Avatar
Here is the thing, you can not learn how to swim by just reading post , you will have to remove your pants and jump in to the water – likewise you have to get some tools and remove the parts that you suspect – then you will know what’s going on
Slash415
Jul 3, 2014 08:28 AM
TUR3Ovtec
Oct 20, 2013 08:26 AM
v-tec23
Aug 19, 2009 10:12 AM
AccordionMAN
Aug 6, 2009 05:58 PM
Metal Typhoon
May 13, 2009 02:35 PM
