is it hard to bleed the clutch?
my clutch i think has some air in the system and i need to bleed it but havent done on this car before. was just wondering how difficult it is and what i'd need
Re: is it hard to bleed the clutch? (biggsac)
Did you check the fluid level ? If the fluid is low you might want to check under the dash to see if the clutch master is leaking, or check the slave for leaks.
Re: (wed3k)
Yeah easy. You'll need a 8mm wrench and some hose (to fit over the bleeder bolt), a jar to put your fluid in, and a friend to pump the pedal. Just make sure when your bleeding it to constantly keep filling the cylinder so it doesn't run empty.
