- Troubleshooting: Usage of Tunerview Version 1
- Can anyone tune a D16Z turbo automatic?? Or should it NOT be done??
- Fried the C60 Capacitor in a P06 Conversion! Help me find possible causes!
- Shorted iacv how do I diagnose dead p28.
- AFR at idle issue
- 92 eg JDM d15b swap Finished.
- Hondata 200b + vafc piggy back
- Help - Smanager stops datalogging TC wheels speeds after some time
- Troubleshooting b17 block with b16 head misfire
- d16y8 down on power
- Any idea with O2 sensor Fault codes
- Hondata Traction Control Help - H23 VTEC Turbo 400whp
- Hondata S300v1 Board
- LIST OF JUMP STARTERS
- Engine Management options for a new build. Haven't done a lot of researching yet
- wideband O2 sensor choosing
- P28 Chips ECU data
- AEM wideband air fuel gauge problem need help
- P08 + 300j doesn't work IAB for boost controller
- Anyone able to tell me what’s been done to my ECU? Pics included
- AEM universal V1 engine management
- ISO: Savannah, Ga S300 tuner
- JDM ECU running a USDM H22A4 - WTF!
- Binary File Transfer into Hondata SManager
- Can someone explain to me how my manifold pressure goes below -1 bar
- Looking for someone to tune my Prelude / FIC6 (near OH/KY/IN)
- Code 23 and code 20 on 1994 b18c Eg
- Help Idle issue with civic EG Eu version
- Yet another 3 wire to 2 wire iacv thread.
- Bosch Oil Pressure/Temp Sensor
- less than -6 timing on Crome?
- Do I need a tune for a rebuilt engine?
- TPS Issue!
- What is t he standard Fuel Pressure of a B series when priming the engine?
- Could H-T gurus please review this ignition/fuel map on this B18C4?
- can't see the forest for the trees (turbo/ecu question)
- B16a2 vs B18B3
- ID1000cc deadtime/tune issue
- TSX ECU and Engine in an 07 Element?
- 97 civic headers
- Is a demon really worth it?
- Issue with AEM Wideband Readings Hondata s300 Datalogging
- Troubleshooting: Strange throttle issue around 2500rpm
- Troubleshooting: Skunk 2 Tuner 3 cams, 11.5:1 CR only making 200hp tuning issue?
- Knocking when Turning Ignition
- P1361 2002 Accord
- I’m interested in using the Jackson racing supercharger
- 1983 Civic Engine Rebuild- Break in/Smogging
- P28 minime running rich
- Datalogging oil pressure - Glowshift Gauge & S300V3
- Hondata Stock Map Question
- TDC sensor
- Found a dyno to rent but the owner wants to drive my car on the dyno...
- Swapping Hondata 300 to new P28 ECU
- Good EProm Chip Reader/Burner S200 Chip Transfer to Bin FIle
- Troubleshooting: Issue with Hondata reading AEM wideband
- Hondata S300 Running a wideband to D10 on Canadian Civics?
- Assistance Needed: No spark at the distributor. (Unknown car model)
- How does one go about Changing the ECU with a Neptune tune on it?
- Wideband display on Hondata doesnt match Innovate MTXL gauge!
- Recovery of Chip Tune in Hondata S200
- Ethanol sensor mounting options: B-series
- Troubleshooting: Hondata S300 V3 Flex Fuel sensor issue?
- fuel pressure not stable and injector leakage issue.
- power FC and Hondata
- need my 1987 honda civic si obd0 ecu tune
- Turbo b18b1 fuel issues WAY TOO RICH
- ECU help needed
- Hondata s300 tuning
- New 86 accord dx build
- K100 guru's need some help
- K100 removal
- Voltage issues
- What pin actually powers the ECU?
- Neptune Demon Rtp users
- 98 crv head gasket
- hondata s300 issues
- KPro on 05-06 RSX-S, what sensors are disabled?
- 2001 Prelude Type SH ECU: I have OBD2 But is it OBD2A or OBD2B?
- Is another Hondata Flashpro needed for my 2019? can I tune with a 2015 model instead?
- Anyone running a Haltech Elite?
- Chipping and adding VTEC to a HONDA P06 ECU
- Fully built LS/Vtec/S300/tuned stutter/no throttle response randomly at 4k-5k.
- Looking for some help with basemap
- B20b running lean PLZ HELP
- trouble with crome launch control, chipped p06 ecu
- Engine Help for 2013 Honda Civic Si
- Analysis: Is this OBD1 P75 ECU stock or was it modified to accept Crome?
- S300 v3 not working
- Very RARE P30 ECU! Need info on it
- Dizzy issues on a b20
- Intake manifold question
- 0v-5v transducers for loggin oil, fuel pressures S300 V2
- Launch control wont shut off, pls help!
- B16 engine swap help
- H22a hondata tune
- 96 Stock GSR - Won't start after testing AEM EMS S2
- Hondata S300 V3 USB Cable?
- What's added to my ECU
- 2000 prelude ecu question
- BARO error code /atmospheric pressure sensor
- ECU and Basemap Suggestion for ZC VTEC engine
- B18 type r low idle, gas smell, horrible mpg, bogging!
- Changing ECU Map while engine running
- Karowinn is in Need of a tune for his B20VTEC.
- Tuning experience w/Sk2 Tuner Stage 2?
- B20 swap trouble reading OBD1 codes
- Engine struggles at 50-100 throttle.
- Will NOT boost past 4.5 PSI. WHY?
- Looking for Skunk2 4 bar voltage table.
- B16a2 High Idle, New IACV
- Looking for help adjusting basemap. Forged bottom end big turbo and water/meth
- Using an F20b ECU in an Integra to pass emissions. Is it possible?
- Troubleshooting: car wont start after upgrading fuel pump w/ higher inj cycle.
- Suggestions of a Reputable Honda tuner in or near Indiana
- Recommend OBD-2 Hardware (Fuel Dilution)
- B16a2 in ej8, obd2a to obd2b conversion (p2t Ecu)
- B16a2 P28 HondataS300v3 RC 550cc injectors CUT OFF 4500RPM????
- Replacement wideband sensor part numbers.
- "Virtual" Dyno (V-Dyno) Settings for Em1? What does one use?
- Help with reading check engine light code
- B16a2 running on a P2P ECU From a D16Y8. Good idea as a temp solution or no?
- flex fuel/injectors with demon 2. How does one use the hardware/software for this?
- Good reading materials for learning how to tune. Where are they found?
- B16 VTEC Turbo issues: VTEC does not engage.
- Built K24a2 all motor - Getting knock in cyl. 1 only
- I'm looking for a H22 Base map for Crome. Anyone have one?
- Kraftwerks Supercharger & Hondata Tune - Car bucks at 5K RPM's in 1st and 2nd Gear
- Assistance needed: Installing Hondata on an ECU board. Ran into a problem
- Is a Canadian Obd2 scanner & codes different than those used in the US?
- Looking for internet Tuner for hire.
- Do I need a basemap!??just put turbo in b20vtec
- 2step launch cut issue
- Tuning 100 shot on B20...wanna do 200
- Troubleshooting: 1992 Accord SE ECM "smoke" & failure
- D14A4 turbo obd1 distibutor problem
- s300 Dash Displays - Let's see what you all are using
- Recommendation on eTune for Hondata S300
- H22 95mm stroke - ignition timing map feedback request
- Can someone explain CAN-BUS?
- USDM OBD2A P30 vs P2T and FTP Sensor
- Problem with Ostrich 2.0
- Crome gold pro dealer lockout
- 02 Sensor trouble code
- hondata blinking red
- RPM based ignition advance, Hondata vs NepTune
- Vtec code 21 on my circle track prelude
- 2 step adjustment points: Is there a "standard" rpm to use?
- T1 Race Development or Boost Logic?
- What components are necessary in order utilize CROME on an OBD1 ECU? How do I tune?
- H23A obd1
- EP3/K20R, CAMCMD<>CAM
- 450 DSM injector on hondata s300v3
- How does one properly calibrate an OBD1 H-series engine?
- Troubleshooting: IACV & pin configuration using a D16y8 head/D16y7 block?
- Newbie alert: what is involved in tuning my F22B1 powered 95 CD7 Accord?
- Troubleshooting: B20 Engine goes into limp mode after installing a turbocharger
- Where can I my 98 EK B16 Tuned? (In the San Antonio / Austin TX area)
- J35A4 + M90 + AEM SD - Tuning Guidance Please!
- How does one fix TPS calibration control in Hondata S300
- Looking for emanage blue maps for Turbo setup
- Do you have a diagram pinout of a Kpro v3?
- Turbo Em1 Boost issue
- Honda del sol with ob2 ECU-change to OBD1 and insert a chip?
- Does the B20B ECU require a knock sensor for the engine to operate normally?
- Troubleshooting : 93 Civic chassis w/ B18A1 Engine - ecu issue/question
- Honda s300 launch control values atmospheric
- D16 OBD1 tuning questions
- Hondata S300 V3 not properly working. Options "grey'd out"
- B18c1 with type R pistons, cams, ECU?
- H22A in Limp mode
- B series turbo stand alone suggestion
- Wide band o2 question
- D16y8 set at 21 degrees?
- B18A1 fully built head stock block
- Tuning Fuel Compensation Sucks
- D16Y7 start engine on ground??
- Neptune BBG. Hitting boost cut
- Setting ign timing with hondata
- Converting a Crome QD2 format to a QD3 format for datalogging
- VTEC Spool CEL #21
- Assistance Needed: KTuner & tuning - how to install & upload a basemap?
- Chip Burning Using Universal Programmer!!
- Open Loop vs. Closed Loop Issues
- Assistance requested. Innovate MTX-L Plus calibration issues
- Is it possible to perform Tuning without an O2 sensor?
- Troubleshooting: information regarding sensor CODE 9 from within the distributor
- Is it possible to utilize Hondata with a P2E ECU ? NO.
- Have a chipped ecu, can I install an s300?
- 2015 Civic R18 misfire with pic of plug: help Please
- ECU Fuel cut/boost cut under load
- B20B Turbo Base Map?
- ECU Selection B18C1 1999 EK Hatch
- *Write-up* - Innovate LC-2 Wideband Settings and Calibration
- KiNGDEE206's official street tune S300 / B18c PCT/ 272 cams
- Troubleshooting: 1993 civic ECM code 37. What does this mean?
- Troubleshooting: Issues with LSV Turbo civic-datalogs enclosed
- Troubleshooting: Aftermarket knock sensor creates noise under partial load
- Is there a method to Tuning injectors with slightly different flow rates?
- Firmware reflashing
- IAT corrections and Open Loop ECT corrections?
- Demon 1.2 question
- Can't find option to write map on CROME!! EK CIVIC
- Wire tuck harness
- K Series sensor specs, research advice needed.
- d16a swap from 96 si coupe to 98 hatch cx.
- Ignition Compensation on E85
- Throttle Tip-in Trim -20%????
- setting up ecu correctly for locked vtec
- need of a chrome basemap for a b18b1 p75
- Odd TPS behavior
- S300 V1 gone bad?
- EPM with Infinity
- What ACTUALLY Triggers V-Tec?
- Assistance Needed: D16 turbo setup from Germany, needs a base map/E-Tune
- Tuning ITB Setups...is it difficult?
- Code. P0301...at wits end
- Rich AFRs
- Troubleshooting tuning: car is progressively leaning out after warmup
- O2 sensor (stock) question
- P2T-A11 JDM?
- Weird fueling issue during high IAT idle
- Wiring in an IS20 or IS38 turbo
- K swap, cruise control & Kpro need to confirm
- AEM 30-4110 UEGO Inaccurate Readings?
- Troubleshooting: ignition timing: which pins to use on P13?
- Spark Plug different color, meaning???
- Fried ECU Injector Driver?
- What exactly are injector latency "Dead times"?
- BRE question about Target A/F ratios.
- Troubleshooting: B18 Running lean at higher RPM
- base map for turbo ls vtec in a gsr
- Air fuel not reading / running dangerously lean
- MA motorsports auto obd2> obd1 setup for boost
- Old Honda Yellow/Green Coil Wire
- Xhorse knock-off Honda driver
- What is the best method to obtain Proper air fuel ratio?
- o2 sensor not working after exhaust work?
- Needing help ordering new motor for 2006 honda civic si
- P28 ECU
- B18c engine running with power fc b16b version
- D16z6 Turbo passing emissions
- Lean condition at idle only
- boost my 1999 ex
- hondata s300 Analog Input 2 voltage problem
- Troubleshooting: Hondata Boost-by-gear value configuration
- Tuning Open Header vs Full Exhaust
- 2004 CRV runnin lean code
- Ecu Pinout for map sensor
- 05 Accord EX 2.4L p0341
