Wire tuck harness
Old Jun 17, 2018 | 05:45 PM
spoolinvtec54's Avatar
Default Wire tuck harness
hi I bought a wireworx tucked harness for my em1. I understand that I have to tap wires into the old chassis harness but how do I tap vbu wire in if it’s supposed to be tapped into connector c.
Old Jun 17, 2018 | 08:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Wire tuck harness
Sounds like a question for Wire-Worx.
Old Jun 18, 2018 | 06:56 AM
I already tried.
Old Dec 15, 2019 | 02:43 PM
Ckincaid93's Avatar
I just put one of these into my ej1. Once you plugged the main harness onto the engine and routed it through the fire wall plug the ECU connectors into the ECU. Then plug the sub harness into the C101 plug behind your fuse box and plug the other end into the sub harness. After everything is plugged in you will be left with 7 wires to splice into the chassis harness. Just match the colors of the wires brown to brown green/yellow to green/yellow and so on
Old Feb 8, 2020 | 10:11 PM
JoeAl12's Avatar
I need help wiring my Wireworx harness, its a b series obd2b.. it shows that the white/ blue stripe is for the vbu but I don’t have that wire I’m only left with a blue/ orange stripe.. also on the connectors side that goes on the ecu I have 3 pinned wires black, white/ red stripes and red /orange stripes do you guys know where in supposed to connect those wires..
Old Feb 8, 2020 | 10:14 PM
JoeAl12's Avatar
Do you guys think that blue/ orange stripe is for the VBU??
I don’t know where to connect this wires
Old Feb 11, 2020 | 03:28 AM
Ckincaid93's Avatar
As far as the first set of 8 wires you have in the first pic look at your O.E. ECU connectors you’ll see which wires match those colors then cut them at the factory connector and splice/solder them into the supplied wireworx sub harness essentially just match the colors. As far as the second set of wires in the second pic I’m not entirely sure my harness was for an OBD1 engine/chassis so that’s the only part that differed for me
Old Feb 11, 2020 | 03:32 AM
Ckincaid93's Avatar
This should help
Old Feb 11, 2020 | 05:38 PM
JoeAl12's Avatar
Thanks for the help and I read somewhere that the extra 3 wires might be to allow sensor additions..
Old Feb 11, 2020 | 06:28 PM
Ckincaid93's Avatar
Ok that makes sense. The one I got was the basic one for an obd1 chassis and motor so the ECU Pinot is different but far easier to hook up than I thought. I also highly recommend soldering the wires or using a 0 ohm crimp connector
Old Feb 12, 2020 | 05:48 PM
spAdam's Avatar
Loved
Community Favorite
Crimps would be preferable.
Old Feb 13, 2020 | 09:45 AM
JoeAl12's Avatar
Thank for the tips guys. My harness is also the basic one I believe stage1
etrent777
Honda Civic (2006 - 2015)
Mar 22, 2014 11:38 AM
D'PEXi
Sep 26, 2011 10:11 AM
soNNy638
Audio / Security / Video
Mar 28, 2010 06:55 AM
07taffysi
Jun 16, 2008 07:24 PM
hitekper4mance
Oct 9, 2007 08:21 AM
