PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Tuning Open Header vs Full Exhaust
  2. 2004 CRV runnin lean code
  3. Ecu Pinout for map sensor
  4. 05 Accord EX 2.4L p0341
  5. D16Y7 upstream/downstream O2 sensor plug question
  6. Assistance Needed: Apexi Power FC on B18C1
  7. A4/D6 ECU bypass bridge with Neptune
  8. Troubleshooting: AEM X Series wideband and s300 management
  9. Opinions needed:Ktuner Vs kpro D17
  10. Troubeshooting: Turbo crv cutting out at 6200 rpm-Tuning Parameters
  11. Integra 2001 Type R ECU help needed
  12. VTEC CONTOLLER
  13. Advantages of P30 over PW0?
  14. Troubleshooting: Major Power Loss in VTEC
  15. Gearing changes vs ECU
  16. Need to learn: How to initiate Crome's 2-step launch system
  17. Troubleshooting: Code 21 VTEC solenoid issues
  18. Can my ecu be saved?
  19. Tallgumby is New to I-4 Hondas and ignition/fuel tuning - Intro guidance needed
  20. Assistance requested: DC5 Integra-Need guidance on Hondata Management
  21. Troubleshooting: Misfire codes after P&P, Tuner1, Valve and Piston swap. Thoughts?
  22. eManage Ultimate gurus? Fuel cut?
  23. P72/P75 OBD1 ECUs (1980 Board)
  24. Engine surging and IAC malfuntion / PVC leakage error ONLY when warm [2003 Civic]
  25. Opinions Requested: Thoughts about remote tuning (A.K.A. "E-Tuning")
  26. Rise fall idle after IACV cleaning. Please help!!
  27. Inline fuel filter fuel lab vs e85freaks.
  28. Is it possible for a P28 U.S. Ecu to replace a EDM P28 Ecu
  29. D15B with hondata s300 and dyno tuned displays fuel starvation symptoms after warming
  30. Driving without a dyno tune?
  31. Using obd2 reader with chrome and obd1 conversion?
  32. Can't get a smooth idle after rebuild
  33. Tune with crome
  34. S100 Tuning
  35. Kpro in 2008 Element help.
  36. crome tuning error
  37. Suggestions Needed: Ecu, Tuner, or fuel injector issue?
  38. Reading ECU used with mid 1990s D16A6 Engine
  39. 1996 accord lx f22b to f22b1 "vtec" - Which ECU to use?
  40. Idle problem after OBD2 to OBD1 Ecu swap.
  41. P28 ECU -Contains unknown EPROM chip?
  42. Honda HDS and cheap MVCI cables.
  43. Request Assistance: AP1 s2000 stock rom bin file
  44. does Mase still have a good reputation?
  45. Vtec pressure switch bypass on obd2a how to??
  46. How can P73 ECU be chipped?
  47. Switching from crome to Neptune
  48. White Smoke B16A problem
  49. Troubleshooting: B-series turbo application hitting boost cut at 3,000RPM
  50. Tuning Question: Using target % Lambda in Hondata Software
  51. Ecu Identification Help
  52. Troubleshooting: DC2R Ignition components options for a standalone ECU
  53. ►► FREE ►► My Entire Tuning Database
  54. Check engine issues hondata s300
  55. Please Explain: "Disable VTEC Spool Error Check"
  56. Troubleshooting: New VTEC OEM ecu programmed to old key-- won't rev past4k
  57. Troubleshooting: Emissions fail on D17 turbo using EP3/KPRO system
  58. Troubeshooting: db2 turbocharged integra fuel cuts at 1psi
  59. General question: How does Engine tuning actually improve its performance?
  60. Assistance Needed: b16 idles rough wants to die out stall at stop
  61. kpro ecu calibration old kmanager version
  62. Issue getting car to fire with new neptune rpt system
  63. ISO, HAmotorsports custom basemap info
  64. Obd2b to obd1 d16 HELP
  65. Assistance Needed: Engine Code P1382- CYP
  66. 9:1 compression gsr pistons and rods. How fo forst start motor.
  67. octane booster until retune?
  68. Car tuned on E85...can it run premium gas?
  69. B18a1 obd0 into a 00 cx hatch
  70. Crome Closed Loop Problem
  71. Supercharging a 2000 EX, questions
  72. Vtec wiring P75 ecu
  73. 92 Acura Integra power issues
  74. Car not starting after installing hondata 4 bar map sensor
  75. Car not starting after installing hondata 4 bar map sensor
  76. P28 weird diagnostic port problem
  77. Troubleshooting issue: Innovate lc2 error 2
  78. Shops near Savannah GA
  79. Coil packs vs aftermarket distributer upgrades for itb b18c1 build
  80. can somebody provide me with a basemap for THIS specific B16A2 Build Please?
  81. Is there a way to use OBD Port to communicate with a JDM ECU in a OBD2B 2000 GS-R?
  82. Troubleshooting: Lean Idle Issue
  83. Using led toggle switch with S300 for Hi/Low map - Possible?
  84. Troubleshooting:GSR b18c1 NA w/ knock code 23
  85. D16A8 OBD0 Turbocharged with OEM ECU - Not sure what's next
  86. random misfire and egr code. to no start
  87. Neptune RTP and flex fuel setup?
  88. Switching from OBD2B to OBD1: Not sure if I know what I'm doing.
  89. Use of IQ3 on Hondata FlashPro or Haltech
  90. Can i make an auto ecu pass inspection in a manual
  91. s300 2-step Ignition Timing Settings: Is this an issue?
  92. Troubleshooting: Turbocharged B16 running lean idle
  93. Oxygen sensor problem
  94. F22 SOHC Base Ignition Map?
  95. Street tune completed Z6/Vitara -results in slow acceleration/top end
  96. Adding RPM Rows (Neptune)
  97. AFR drop while WOT at 7500 rpm
  98. HIGH IDLE AND RUNNING RICH!!!
  99. 92 civic fuel problem
  100. NEED Help with 2009 Honda Accord cope 2.4 Engine
  101. 97 civic temperamental no-start
  102. Ignition advance and retard spikes?
  103. How do i install my Hondata4Port Boost by gear solenoid. CONTROLER two wires?
  104. P28 virgin limp mode Fixxing
  105. New Knock Detection Tool
  106. P0172 and a short ram intake
  107. 93 GSR b17 cranks but no start
  108. D16z6 cylinder/spark plug spacer??
  109. Tuning a vtec
  110. OBD1 P28 Minimum wires to Test ECU
  111. Retune needed for switching MAP sensors?
  112. Opinions On A B20 Basemap In Constant Open Loop
  113. Need input on this basemap please.
  114. B18c1 turbo AEM series 2 EMS not starting
  115. Issue with crome, simple fix?
  116. 99 OBD2B to OBD1 Conversion for Automatic D-Series Engine Management Options
  117. Dumb Question about DYNOTUNING
  118. problem with s300 and wideband
  119. Ground wire disconnected, car loses power until shut off
  120. B18 swap 00 civic help
  121. 2008 Honda accord 3.5l
  122. Trutime Cam Gear/engine timing question
  123. D16Z6 ignition issue?
  124. What is a fair price for a tune up?
  125. Doctronic ECU for D14/D16/D17 01-05 Civic
  126. Diagnostic Issue: VTEC will not engage using Web Camshafts *SOLVED*
  127. 99 Accord v6 (300k) - Intermittent loss of power
  128. Help! How to reproduce o2 sensor after delete
  129. Online Tuning Courses
  130. looking for a base tune
  131. TPS cel nightmare
  132. Help/Advise starting a basemap in Neptune
  133. Diagnostic Assistance Needed: CEL P1457 - Evap leak?
  134. 92 integra GS
  135. Contemplating DIY Socketing a B20 ECU for a dynomometer tune session
  136. h23a vtec help
  137. Inquiry: Which ECU is needed to run a JDM B20B Swap?
  138. Admin Please .. Maybe Move Linked Post Here?
  139. calibrating 4bar map sensor on s300
  140. Hondata S300 OBD1 P28 B18A1
  141. S/C Kraftwerks kit installed with Hondata flash base map
  142. gauges thru s300n v3 for datalogging then out to a aim mxl strada
  143. Recent Tuning Experiences in Texas?
  144. 1.8 SOHC (R18) VTEC POA ECU Questions
  145. Need help tuning K20 for 87 octane using a flashpro. 8th gen Si
  146. Hondata causes Car to "bog" after skunk2 Intake Manifold Install
  147. Please look at my Datalogs
  148. AEM FIC6 Tuning a B18A OBD0 PR4 Code 9
  149. O2 sensor/map sensor/fuel supply metering help!!!!!
  150. 1994 d16z6 no start after driving on hot day
  151. Spark plug reading xd
  152. Best MAP sensor for 1.5
  153. Setup Question: How do I setup Hondata's "boost by gear" Option?
  154. AEM Infinity 506
  155. Innovate LC-2 Malfunctioning (video attached)
  156. K20A3 to K24A1 Turbo - what Map to drive to tuner?
  157. Assistance needed: H23a blue top ECU problems
  158. advanced timing until knock (VITARA SETUP)
  159. Losing 50HP on Dyno during VTEC Cross-over
  160. setting up boost solenoid
  161. Disable CEL
  162. Please help!!!
  163. AFR extremely rich while o2 sensor is heating
  164. Remove chrome for honda
  165. Diagnostic Question: TPS Sensor not reading on Hondata with Engine Running
  166. Wiring ECB-1 flex fuel to S300 V3
  167. Wiring ECB-1 flex fuel to S300 V3
  168. My timing maps, and how much retard per psi on e85?
  169. How much and what is needed to tune OBD1 Accord?
  170. Suggestions Needed: Budget-minded Engine Management Options
  171. Hondata s300 v3 + Flex fuel sensor
  172. Is it possible to run A Hondata Prepped K20 ECU on a K20A6 Engine Harness w/ no tune?
  173. 96 LX cylinder 4 misfire. Help!!!
  174. Is it possible to Self-Prep and execute KTuner on the OEM ECU w/ its Immobilizer?
  175. S300 V.3 tuning issue
  176. P28 fuel prime issue
  177. Crome Free Download
  178. Stand alone K, what are my options.
  179. H22a oil pressure sending unit psi crossover
  180. How to test an ECU for VTEC Engagement
  181. Rebuilt d15 minime turbo basemap?
  182. 91 CRX EF ECU Pinning
  183. diy tuning for k series similar to neptune?
  184. Obd2 to obd1 pigtails problem
  185. Diagnostic Issue: P0325 CEL on D16y8
  186. 92 accord code 43
  187. Need Help with 2009 Honda Accord
  188. Suggestions Needed: AEM EMS 30-1040 or Hondata S300V3 & why?
  189. Diagnostic Issue: Datalogging Wideband Error with Hondata EMS
  190. Buying an EF- 1991 RT4WD Wagon or 1991 DX Hatchback
  191. What Is The Proper Air-Fuel Ratio Needed To Safely Drive My Car?
  192. OBDI / OBD2B OEM ECU swap question
  193. Diagnostic Issue: BBG setup troubleshooting
  194. obd2a ecu, odba interior loom, obd2b engine loom problem
  195. Where does one receive training on the Hondata s300 software?
  196. Aem series1 1020 offline Issue
  197. Diagnositic Issue: Large injector B18C - Engine stall while opening throttle
  198. Hardware Issue: crome pro datalogger timed out
  199. Flashpro 2006-2011 civic SI ECU Tune for smoother throttle
  200. Using a Cell Phone's Accelerometer as a "Butt Dyno". Possible?
  201. P28 what chip to use
  202. problem tuning with neptune basemap
  203. jdm b18c 11.1 on 93 pump gas
  204. Code 22 on d16z6 1994 hatchy
  205. MAP sensor issue?
  206. PR3 Pistons in B18C Type R JDM
  207. chipped p28 b16 lumpy idle
  208. EK9 Import in Switzerland... Issues with emissions
  209. Suggestions needed: Any efficient methods to improve my map's ignition/fuel trim?
  210. 96 integra ls won't start... Checked for spark and new plugs but what else....
  211. 96 integra ls won't start... Checked for spark and new plugs but what else....
  212. Civic Type-R el. steering column control
  213. Assistance needed: OBD0 fan senor issue
  214. hondata cpr troubleshoot
  215. Looking for tune in NYC area
  216. 99 EM1 CEL
  217. *&^%$%&*! broken spark plug!!!! still in motor......please help
  218. question about running two ECUs in parallel
  219. lean mixture at small throttle changes
  220. Assist Needed: management choice for turbo F22B
  221. where to start tou tune afr ??
  222. A/C idle issue on H22A P28, S300
  223. DIY electronic det can build
  224. Suggestions for tuning due to lack of resources in local area
  225. Would the following issues listed point to a bad o2 sensor?
  226. tunning with chrome to pass state ref
  227. Question of Authenticity: Hondata S300 with 11 rows of heatsink???
  228. Hondata S300 V1 with 11 row heatsink??
  229. Hondata S300 V1 with 11 row heatsink??
  230. Hondata s300 update. Stalls when pressing throttle
  231. What particular symptoms would lead one to believe they have P28 capacitor issues?
  232. Feedback on 92 Accord H23A1 street tune
  233. P72 Questions- Knock sensor and poor idle on closed loop
  234. Feedback on my Street Tune?
  235. 2005 Honda Pilot 3.5L throttle plate adjustment?
  236. AEM series 1 newb
  237. Open loop tune coming to a close!
  238. Flashprotuning.com is back, sort of.
  239. Stock b16 turbo basemap in need
  240. P28-A51 w/Manual Trans?
  241. K-Pro in a newer chassis.
  242. Open loop elevation changes
  243. Can I daily drive with a basemap?
  244. prelude OBD2 to OBD1tranny conversion
  245. 94 eg civic sedan f23a1 swap
  246. IAT sensor problem
  247. Is it a bad idea
  248. How to run d16y8 on a obd1 harness
  249. need some input...regarding a p5p-a02 ecu?
  250. K-Pro on a non-K engine
