Ecu Pinout for map sensor
Old Apr 1, 2018 | 08:30 AM
boostedblue23's Avatar
Default Ecu Pinout for map sensor
ok so I live in jersey and need to get my turbo 2000 civic si to pass. I plan on putting the stock ecu, and injectors in to pass. The problem is there is no map sensor on my harness. I guess previous own clipped it. Can I run the wires straight from the sensor plug to the ecu? Anyone have the pinouts for the stock b16a2 ecu? Thanks!!
Old Apr 3, 2018 | 07:59 AM
850Fabrication's Avatar
Default Re: Ecu Pinout for map sensor
If the harness was cut, find the part were it was cut and simple repair the wiring.
technet.ff-squad.com for wiring pinouts. The map sensor has its own dedicated 5v reference and signal wire but it will share the sensor ground with the IAT and TPS.
boostedblue23
Apr 6, 2018 06:53 AM
Robs_B18c
Nov 4, 2009 08:39 AM
Hatchls1
Dec 13, 2008 09:43 AM
