- crome tuning in COLORADO
- Primary OBD1 o2 senor same as Primary OBD2 sensor?
- Tuning with crome questions
- Tuners around inland empire
- Valve Overlap and O2 Accuracy
- Camshaft Tuning
- ecu pinouts
- p28/gsr ecu ??
- h23 basemap request in crome format either through email or links ONLY
- dizzy to coil pack question
- OBD2 and different tunes
- best place to tune in NE
- Help! How to dismantle 110cc Motorcycle Engine
- Custom Chip for P30 ecu
- Disabling VSS?
- 1st gen B16 has 2 oxygen sensors....HELP
- Proper Plug Gap for Custom Motor
- Disabling IACV in crome?
- Cam timing changed: can't get ign. timing right.
- Who can tune a neko ems!!!!????
- engine wire harness questions
- What temp/pressure senders to use with tunerview?...
- good affordable wideband??
- HELP My Car Is Acting Up HELP video soon..
- Need Basemap to get my car running
- Best H22A setup need help
- Basemap almost undriveable
- Turbo Edit Question
- Engine tuning Basic
- what about this ecu
- H22a With basic boltons
- check engine light/shift light
- what does ecu do?
- Ectune vs. Hondata
- B Series/S300/Timing figures off between ecu/laptop and Actual crank.
- Help before I buy!!
- TRU-BOOST Gauge
- Gsr ecu
- ecu vs. ecu
- TPS @ 1% at idle, O2 reads 3.85v
- Tuning pre obd ecu's aka pr4's
- Leaking camshaft seals and a faulty repair
- back fire during shift is this normal
- weird idle issue
- Is vtec not engaging because of tune?
- P06 in B16A Convert?
- Best h22 (FI) tuner in the westcoast?
- Just replaced my Idle air control valve, now its idling too high! help!
- b20b vtec
- cam cap install b16a
- pgmfi forums down?? uberdata needed
- How long have widebands been cheap/affordable?
- PLX M300 wideband
- crome
- Saving up to buy a laptop for tuning what should RAM be like?
- 1998 d16y7 Civic: CEL
- Need help withEvap canister
- HELP!!! JDM b16a tranny (STICKER VIN?)
- Datalogging AFR w/ an AEM wb and Freelog.
- custom B series crank Pickup
- Emissions help with ECU
- automatic p28, can i convert it?
- 8 injectors on hondata????
- PR3-J00 Speed governer?
- b16 throttle body help
- I need a wiring digram for an obd0 b16a ecu
- spec on 1600cc precision injectors??
- hondata ?
- 2,5bar MAP Sensor with K-Pro
- Engaging launch control in S300... AC Switch?
- cars running rich need help n idle problem
- 91 Civic TPS qestion
- Tuning with S300 on a Mac, possible?
- B20 Vtec ?
- Vtec Tuning
- Yoparts new op amp Map sensor?? ADVANCED DISCUSSION
- ecu chipping capacitors and resistors??
- stupid idea?
- Ems?
- fpr worth buying
- need this car for xmas please help!
- Problem: US gsr going to US itr pistons: HOW DO I TUNE IT?
- Moates Burn1 Chip Programmer problem: reads but doesn't write
- oldd hondata
- pump gas to race fuel
- i need a boost map
- Engine identification
- need a capacitor for a nissan
- Accel dfi gen 6
- Baro sensor?
- best obd conversion harness?
- BLITZ DTT (Dual Turbo Timer) DC IV question??
- Launch Control??
- Pop Bang exhaust question about this car
- obd 0 tuning
- code 10 and 4 ????
- DataLog Adaptor Question
- Home made boost cut for crome
- hondata s200???
- k pro help?!
- Can't get a hold of my tuner. Can I...?
- ECU Measurements Questions
- What Electronics???
- 2001 GSR w/ skunk2 manifold
- anti-lag or 2 step
- ecu tuning options for d16y8
- 1600cc injectors
- 880cc precision injector help
- Dsm 450's on honda ecu
- Launch control not working
- Can any one help me get the best of my vei
- P28 w/ a burned circuit board. What's burned?
- Cant burn AT27C256R with willem
- Please check my map
- Having problems connecting OBDII scan tool software to 99 Civic Ex
- S300 boost control problems, no control!
- crx temp guage not working
- Looking for a tuner
- in need of an ETM please!
- Need Some Advice DOHC ZC
- D15B Swap, tuning questions (new to hondas)
- noob? after datalogging...
- Anyone ever use a SFC Vtec controller
- car will not hold idle/rev
- FJO injector drivers?
- Whats the BEST temperature to tune a car?
- Best chip for a P73
- need a little help
- aem problem -coil wont fire-
- which exhaust is better for a 95 eg?
- ECtune & NEPTUNE RTP PROS/CONS
- E-Manage Ultimate
- wideband o2 question
- S300 Walk Thru to check for slight miss issue
- Extra P06 chipped and vtec converted, some ??'s
- accel dfi question
- Running rich issue
- S300 how to tune it???
- vafc questions??
- Need ECU help.
- HELP!! Installing an Apexi S-AFCII
- Try my tool for FreeLog and Crome! EasyMap!
- Getting Started with Tuning, Crome and Freelog
- 95 integra w/ JDM H22A1 swap Help???
- Total Cylinder Equilibrium tuning
- Open Header vs Open Exhaust
- New Crx.. Tuning questions?
- tuning type
- Question about wiring resitance
- MOTOR OIL???
- Help with S300 ITB map
- h22a sensor plugs/ connections
- voltage correct for rc 1000cc injectors?
- s200 troubles
- Differnce between AEM 1020 & 1060 ecu's?
- Wideband O2
- Looking for a tuner in Socal
- H22 lude won't rev pass 5300
- i need some help it won't redline!
- S300 & M&W 4 channel CDI, can it be done?
- OBD2 Auto to manuel ecu conversion
- Auto to Manual ecu conversion?
- Fake? Spoon chip on P13
- type r ecu into gsr problems.
- Books
- leaking injector or faulty tps?
- Is there any plug an play for honda v6
- S100 problems
- S300 calibration help - d16y8 d16z6
- B16 fuel pressure
- 96 CIVIC PROBLEMS
- Cant connect to com port... Crome
- How do you install a 4 pin header??
- Help with turbo timing
- ecu help
- moates.net hondalog and crome
- Upcoming Haltech Platinum ECUS
- Engine will only idle with rich AFRs
- Learning basic ecu tuning.
- white smoke from my exhaust?
- Hondata s200... HELP PLEASE
- Want to get a chipped ecu to run with stock map
- will p28/obd1 harness work on b20
- Differences in B20 ECUs?
- idle quality on 680cc's with ectune
- Chipped ECU usage
- OBD2-OBD1 w/auto
- fried ecu's at the same spot
- ► Official Honda-Tech Announcement.. Must Read
- Dual Point Fuel Injecton to Multipoint Fuel injection !!!! HELP!!!!
- Civic Si Hondata Reflash (ECU Upgrade)
- Speed limiter with hondata
- Surge
- AEM wideband hookup question.
- AFC NEO or E-Manage??
- hondata s200 questions
- OMG!! I Have a Bad oxygen 02 sensor! What should I Do?!?!
- Shorted out ECU
- Hondata and a gameboy?
- hondata s200
- Reading Dyno (b18c1 on n2o) What happened?
- P05 ECU, Converted/Chipped
- I need some opinion on Central Florida Turbo
- aem uego and hondata?
- how do i get ahold of the crome?
- trouble connecting s200 to laptop
- Will adding a catalytic converter change the A/F ratio?
- tuning!
- Hondata S300 and innovate A/F voltage offset questions
- help with C.O.P. being run from the ecu.
- running lean???
- looking to find ref sync (motec)
- Adjustable Cams?
- ectune diy
- Chipped P28 acting goofy
- Getting >100% duty cycle on 550's!!!!
- vtec problems
- obd0 tuning
- Quick advice on dumptube please..
- how to get hp
- AEM UEGO
- Advancing OBD-II timing on an accord
- Differences Between Greddy Ultimate vs Hondata s300(Post your opinions)
- Disabling immobilizer on a p5p (5g Lude)
- need s200 base map please help!
- Hondata S300, basic how too
- Anyone use Stinger EMS?
- ECU R-135 circit fried!
- Anyone using Apexi Power FC?
- COIL ON PLUG!!! PLUGS & MISFIRE/IGNITION ISSUE
- problems with power fc ign timing need HELLLLLLLLLLLLLLLP!!!!!!!!!
- How to install S300 board in a P28 ecu?
- gsr running rich post tune
- crome full throttle shift??
- greddy emange
- Weird leaning out Issue.
- Looking for a good tuning shop in the Naples, FL area...
- help with hondata s200
- Need help choosing a tuning/piggyback unit for smog
- Is it worth chipping my ecu for a stock engine?
- Need help with chipped ecu
- EFI 101 Memphis, TN
- Im a cheap ass. Need my car tuned. Looking for options.....and tuners lol help please
- Honda Injector Deadtimes
- S300 2step and full throttle shift interference?
- Im new and have a tuning question for a d15b7
- pwo vs pr3
- tuning lstvec
- throw down hxc tune for a/f
- spectre 7100 ems
