PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32]
  1. Dead Computer, How to test???
  2. I LOVE s300
  3. apexi S-AFC tuning/wiring
  4. How to upload from the ECU to computer w/S300?
  5. noob ecu help guru's need
  6. Has anyone built/tuned a car just for Partial Throttle and good gas mileage? Gas PRICES SUCK!
  7. Datalogging not showing any "values" in lambda table with Crome Pro.
  8. Ostrich 2.0 not working correctly with Crome Pro.
  9. help my vtec not working
  10. wut things i can do to make my b17 faster
  11. Neptune + AEM boost solenoid?
  12. Fuel Map for Stock H22
  13. B18c with Pro1's Basemap (S300)
  14. kpro knock and knock threshold weirdness
  15. EFI University- Thumbs UP!
  16. Idle tuning issues
  17. Air fuel Ratio at Idle.
  18. Neptune-RTP and Tunerview
  19. Direction
  20. the more rpms the more it breaks up
  21. How do I replay datalog on s300
  22. Hondata S300 and O2 wideband options
  23. Part throttle tune advice?
  24. A/T lock-up solenoid Code 19 on a Manual ECU Help?
  25. Voltage settings for AEM Uego Wideband in S300
  26. My Chipped/Socketed ECU Questions
  27. PLX M300 wideband wiring- Hondata s300
  28. odd IAT logging with Crome Pro 1.5
  29. What ecu is used with an auto D16Y7?
  30. greddy parts question, will these plug in directly without...
  31. Hondata Bluebox
  32. can I tune with a PR3 ECU?
  33. Discussion: Reading spark plugs
  34. Need Help, O2 sensor problem
  35. WHERE IS THE HIGH CAM AND THE LOW CAM MAP
  36. wideband wiring
  37. What year Gm 3 bar map sensors
  38. Loaded Neptune onto my dedicated laptop, now Crome won't open and wants to send error report
  39. vtec VS non vtec ECU.. will it be a problem?
  40. what is a 2nd gen b16 head from?
  41. Crome and Hondata
  42. Effect of Longer Stroke?
  43. Emissions and OBD2 Swaps in Newer Cars
  44. P06 Chipped ECU Help Needed
  45. PS9 acts up after 10 miles...
  46. Hondata S200 w/boost socketed on P72ECU
  47. wiring PW0 harness to OBD1 connectors for Hondata S300
  48. Idle problems?
  49. Wonderful smell of burning Ecu in the morning.
  50. anybody using opensource stuff on linux boxes?
  51. Crome Pro Auto Tune
  52. Having Problems with brand new B18 build
  53. OBD1 ECU pinout diagram?
  54. P06-P28, HULOG, Crome problems. ready to pull hair out
  55. FAST dual wideband
  56. Crome Gold
  57. Can I use a chipped Honda ECU to convert my motorcycle to EFI?
  58. Any experience with Tuning capabilites of a Vafc2
  59. B16a2 Turbo 7psi Pharable.net base map, searched!
  60. Car Bogs-Part throttle
  61. cannot connect to ecu and need some help
  62. LSVTEC Basemap?
  63. Need a tune on turbo integra.
  64. plx users help me out
  65. AEM help
  66. JDM H22a typical final timing
  67. Greddy SMI control unit
  68. Changing map sensor to 4bar and tuning question with crome.
  69. No secondary o2 sensor on my 01 integra gsr...
  70. b20 in integra
  71. 28 pin socket
  72. getting the car started
  73. Temporary emanage use info
  74. Hondata s100... nitrous control?
  75. AEM WB 02 + Hondata S100/S300/KPRO
  76. ? WHICH PISTON & RODS SHOULD I CONSIDER FOR 100 SHOT NITROUS ?
  77. Tuner advice on EMS platform - 225whp 2L HPDE motor
  78. Tune or no?
  79. Is this all I need to tune my car. (PICS INSIDE)
  80. ECU doesn't have cel light or scan bar
  81. when is engine management needed?
  82. Advice for the youth who are thinking about entering the auto tech. field??
  83. How to tell is my ECU is chipped?
  84. aem 2 step launch control
  85. is there a way to datalog on mobile 6 ?
  86. car dies immediately when i touch the throttle
  87. Check CEL codes
  88. Need a Map for b20.
  89. Ignition timing thoughts
  90. aem 30-1000 vs 30-1040
  91. VAFC2 and Chipped P28
  92. turbo gsr wont start. need help
  93. ecu ?????
  94. distributor king wiring
  95. k20a2 runs rich in cylinder #4
  96. change tune?
  97. hondata tuners please help
  98. Don't know if this info is shared freely but looking for h23 boosted basemap in crome
  99. How To: Convert to Distributor-less Ignition (requires standalone)
  100. Haltech Plug and Play Full Standalone Development Thread OBD1
  101. Need help selecting ecu
  102. hondata s300 innovative lci install
  103. another dead Q31... maybe...
  104. Neptune to Hondata
  105. 2000 Si
  106. crusing ignition
  107. datalogger issue
  108. Hondalogger vid HELP!
  109. tps problems
  110. Wideband reading off?
  111. wideband o2 sensor to autometer air/fuel guage
  112. Which basemap to start
  113. Car dies at low speed
  114. Looking for a base map if anyone might have one or any advice first time tuning
  115. ECU issue
  116. looking for a aem tunner in tn
  117. Help me troubleshoot these plugs...
  118. hondalog usb -- can't get it to log anything
  119. any word on the APEXi AFC nea???
  120. OBD0 Tuning
  121. You guys know Fuel Control better than I do. Tricky.
  122. Car running lean
  123. Need the Free Crome program
  124. how should i tune this?
  125. h22 map
  126. How to post cal and datalog on H-T??
  127. tuning, obd2, emissions - how's it done?
  128. Power FC
  129. Ideas on what to buy
  130. P06 ecu Vtec Conversion w/ PWM Boost Components, is this correct?
  131. 2-step on crome
  132. CarMD, any good? OBDII Diagnostics reader
  133. B16... how many rpms are yous guys running?
  134. new D16z6 swap
  135. PLX M300 integration with S300 question
  136. anyone know what this is....
  137. looking for a multipurpose timing light.
  138. stock chips
  139. Speed govenors...
  140. s300 fuel cut problem.....
  141. OBD1-2A problem
  142. noob at tunning would like to get setup to tune my car
  143. apexi vafc
  144. Daily driving tuning/ WOT tuning all in one???
  145. base fuel and ignition map for h22a
  146. Chipping Question
  147. CROME CHIP HELP
  148. Somthing is going on with my car
  149. Will changing my trans ruin a tune?
  150. Hondata k-pro or AEM ems?
  151. CAN ANYONE GIMME A GOOD B20VTEC BASEMAP?!?!?!?!?!?!?!!?!?!?!?!?
  152. p2e any1 heard of this ecu?
  153. Allmotor total timing at WOT
  154. Throttle cable loose?
  155. need help with crome!!!!!
  156. Crome boost problems
  157. Noob Question
  158. Connecticut N/A Tuner for Chrome
  159. using a small motorola 3 bar map sensor, what specs to use in crome
  160. Good reading for tuners
  161. No working tach with P28, but working with stock p73 ecu
  162. p28 automatic convert to manual?????
  163. How should this be tuned?
  164. Ostrich 2.0 Emulator / Romulator
  165. Does crome disable iacv
  166. Thread Subject Titles ***PLEASE READ BEFORE POSTING NEW THREADS***
  167. LS/VTEC JRSC - STG2 Skunk2 cams - Lean crossover
  168. Hondata s200 question
  169. widceband controller ?
  170. logging afr in neptune. why is it off from the gauge???
  171. Solid Cel in Crome every time ectune basemap runs mint
  172. hondata s300 with all motor gsr
  173. K-Max Speed ECU from Japan
  174. B18A1 bogging at low rpm
  175. civic b18a1 out of 93 integra question
  176. greddy e-01 problem
  177. dyno tune in the Vancouver BC area
  178. I Have a B20 Vtec/B16 With a Sensor Problem? VTEC DOES NOT WORK?
  179. ELD wideband in CromePro
  180. Noob Question
  181. Injector Problems
  182. Hondata HondaLogger s200
  183. wiring problem
  184. OBDO to ECU
  185. Converting OBD0 to ECU
  186. how to: install neptune rtp
  187. FAST EMS info
  188. AEM UGEO and Ostrich quick tuning question...
  189. 2step?
  190. i need info on using a wideband with the hondata s300!
  191. Problem With CN2 Header - JDM GSR ECU
  192. WIRING PROBLEM ON EK9ER
  193. The VX civic and the HX civic use leanburn, higher octane a good idea?
  194. pr4 or p75 ecu B20b4
  195. b18 in oregon tuning noob. help!
  196. a question about my setup
  197. VTEC engagement with VTC cam angles adjustments
  198. ecu quetion about when vtec kicks in. please help !
  199. JDM ecu.....?...?....?.....
  200. Engine Management, fuel tables and ignition tables
  201. Problem Chipping a JDM P30 ECU. Help!
  202. Excited - Chipping (well rechipping) my first ECU
  203. obd0 ecu?
  204. Stinger 4
  205. tuning ecu pass smog?
  206. Tuning with CROME?
  207. S300 at high load at idle
  208. tunner for k-pro
  209. Tuners........ max timing on 93octane???
  210. anyone know how to reset an APexi AFC controller
  211. Are Wiring Harnesses interchangable
  212. pinout for zdyne pm8? pin b19 oil pressure or knock sensor???
  213. chip problem
  214. p08 ecu
  215. Best WA or OR Tuner
  216. not Honda but ECU related: 88 Mustang stock ECU tuning programs? (for race car)
  217. anyone know these knock detectors?
  218. What are the limits for the stock ECU?
  219. oscillating fuel delivery?
  220. Correct way to change injector size on S300
  221. does any1 have......
  222. b20b basemap or full tune?
  223. how to tune in an aggressive sounding 2 step
  224. Need Help on P28 Circuit Board
  225. Starting point
  226. Tuning for MPG
  227. AEM EMS injector assignment questions...
  228. Tuning books, articles, etc. Ways of advancing your knowledge
  229. Determining the optimal vtec crossover for boosted motors?
  230. Vtec Tuning and cold air intakes
  231. south orange county tuners...
  232. **** For Sale/Wanted ****
  233. Maximum MAP for closed loop
  234. Hondata S300 calibrations
  235. ►►Tuning FAQ & RULES►►
  236. Rules of the Land
  237. ECU HELP!
  238. For those who wonder about "spoon" chips on eBay.....
  239. help stock type r.bin for turboedit
  240. Will a P28 ecu run a b18b1?
  241. p30 ecu with b18c1 gsr
  242. eCtune, new tuning software, looks awesome, apparently will kick Crome's ass (discuss!)
  243. PR4 ecu
  244. If ecu is chipped/socketed for hondata s200 is it the same as if u chip/socket for crome
  245. Chipped p28 - not priming fuel pump
  246. Technical Discussion on Tuning an FI car from Scratch
  247. SMC+ Instructions and additional assistance needed
