ID1000cc deadtime/tune issue
Old Aug 29, 2019 | 06:31 PM
spoonhbk11's Avatar
Default ID1000cc deadtime/tune issue
Hi, I have got an issue at the moment with a rough, irratic, and nonstable idle. All seems on point. There's no error codes, leaks none, etc. car starts but won't hold idle and motor shuts down after a few seconds of run time. Only potential culprit is fuel pressure at 2xpsi at engine shut down time. Also, I think may be injector deadtimes.
Please any suggestions reply thanks.
Old Aug 31, 2019 | 10:30 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: ID1000cc deadtime/tune issue
You need to have 43.5 or near that for fuel pressure. Have you played with the dead times yet? I just look up what ID recommends and it’s usually pretty spot on for what works best.
Old Aug 31, 2019 | 11:26 AM
spoonhbk11's Avatar
I have tried dead times recommended 45psi of injector dynamics flow chart, hondata ID1000 deadtime setting, and well I'm not sure if the fact that fuel pump psi upon prime/shut-off that's registering 20psi is normal. I don't see any leaks, have regulator but don't know if need to adjust.
ja20_eg
Engine Management and Tuning
10
Aug 18, 2012 06:33 PM
GsrIntegra789
Jun 9, 2008 08:34 PM
nasteboyii
Jul 23, 2005 06:44 AM
winterbear09
May 4, 2004 10:11 AM
raene
Dec 23, 2002 10:49 AM
