Help with reading check engine light code
Old Jan 27, 2019 | 08:23 PM
hunter fitch's Avatar
Default Help with reading check engine light code
Can somebody please help me with reading the check engine light code? I can get it to flash nut i just dont understand how to read it. Thanks
Old Jan 30, 2019 | 01:05 PM
TheShodan's Avatar
Moderator
Default Re: Help with reading check engine light code
Can't get more direct than this. Good luck sir
CEL CODES 92-95 and how to read them
HA motorsports CEL code list
Old Feb 1, 2019 | 10:18 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
If the car is something obd1 converted and doesn't have the two wire connector to jump the check engine light jumper you can ground ecu pin d4 direct to chassis to make it flash. thatd the far right ecu plug looking at the ecu plug side first. Bottom row second to the left.
Old Feb 1, 2019 | 11:12 AM
TheShodan's Avatar
Moderator
I don't think the OP is that advanced, K7.. Not prepared for that kind of work, simple to us as it may seem.
lgoodgrace
Apr 27, 2015 03:43 PM
hothondas
Aug 4, 2008 06:24 PM
SmogKing
Aug 3, 2006 12:48 PM
Egezzy
May 6, 2006 05:53 AM
350z-tech
Nov 7, 2001 04:19 PM
