PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32
  1. activate nitro
  2. Hondata S300 USB issues
  3. Why exhaust pop pop at 2xxx rpm?
  4. Missing a throttle body piece
  5. Noise coming from underneath the valve cover.
  6. newbie ? about wire harness
  7. can you chip a p08 ecu
  8. P06 in D16z6
  9. So how do you cali guys do it?
  10. NGK AFX Wideband wiring for S300
  11. dei 555i bypass module on a prb ecu?
  12. in need for a table of sensor voltage vs temprature iat+ect
  13. obd1 1.5 vtec in a obd2 ek hatch
  14. Tuning for 300whp = tuning for 500+whp
  15. Please make a plug guide
  16. Will an MSD Ignition throw off my tune?
  17. These obd2 to obd1 coversion harnesses good?
  18. Blown q31 (iat) replaced IAT and code is gone??
  19. HELP QUICK!! vtec p06 conversion.(rm11)
  20. Few tuning/ECU chipping questions..
  21. Weird chipped ECU issues (on crome)
  22. calling all tuners has this ecu been modified
  23. Maps
  24. How to install full throttle shifting switch
  25. ignition timing help!!!!please :P
  26. AEM EMS Base Map for 1999 Prelude Supercharged
  27. wtf.
  28. fixing a craped ECU
  29. Cant start - changed to hondata in civic VTi in a mini conversion
  30. chiped ECU o2 sensor?
  31. Returning MSD to stock..problems
  32. For the guys that chip ecus
  33. dyno wants me to bring car there before starting it?
  34. 37820-p73-a04 ecu plug and play for 01'' itr swap??
  35. Dynojet wideband cable
  36. Please Help My PWD JDM Rad stay don't fit my Mishimoto radiator
  37. >>> OBD1 P72 or P30 ??? <<<
  38. Looking for someone to wire a series 1 universal box.
  39. two questions h2b ecu injector and who to trust for a good chip/soldering job
  40. obd2d16y8 conversion to obd1d15b dizzy plug
  41. Anyone have 37820-P30-N01 Bin? JDM Small case style
  42. Anyone have or know where to get base map
  43. the right chipped ECU for b16
  44. Sensor Calibration.
  45. VAFC wiring need help
  46. LS/turbo needs for a good DD
  47. RPM gauge problem w/hondata
  48. *** Chipped P78 ECU for a B16A Swap?? ***
  49. low idle
  50. looking for some help ! for those who have automotive skills
  51. s300 p28 showing knock error
  52. Two Stage Launch Control
  53. two step question
  54. obd2a to obd1 iacv question,
  55. Which ECU chip/system/etc for ST Class EG?
  56. tuning on a pr3
  57. could sumone help me please with my b16 swap
  58. obnoxious engine studder
  59. Which ecu pinout for Tachometer
  60. HELP! Replacing Resistors R136 and R138 in p72 ECU
  61. Bad ecu soldering?
  62. 2 wires iacv, which wire goes to where?
  63. need help identifing this
  64. need help i did a jdm b16 swap in my 99 civic and now my gauges wont can anyone help
  65. 2 ?'s.. problem with AEM wideband, RC fuel pressure?
  66. tuning for better fuel economy
  67. Chipped p06 ECU quit working?
  68. p28 crome b16a help!!!
  69. ecu trouble (p30)
  70. P30 ECU TROUBLE, THING SHORTED THE F OUT
  71. ecu chipping specs
  72. need help with a pr3
  73. p2p ecu, fried r176. what is it for?
  74. ectune.com down, can't run force update.
  75. Crane Cams PS92 coil question
  76. crome - vtec ecu non vtec motor, low profile map as antirofile for tuning-lag map
  77. civic cx with d16y7
  78. AEM EMS ignition timing
  79. learning to tune...
  80. tunerview question
  81. eCtune Purchasing Question
  82. D16z6 question
  83. CRV K24 engine tuner
  84. D16z6 -> D15B (JDM) PCM Mystery
  85. which ecu to tune D16y7
  86. Crome Problems.
  87. can you please help me?
  88. uber???????? help
  89. header and tune??
  90. 02-04 KPRO ECU in an 05-06 DC5
  91. what is the best system
  92. cant get my laptop to connect to ecu?
  93. Boosted OEM P30, Max ign adv. ?'s
  94. h22 crome tunning
  95. My AC is not cold enough.
  96. ECU P28 or P72 for B18C R
  97. AEM 1040 jumper settings?
  98. k-swap.... MAP problems
  99. Chipped P28 occasionally getting CEL 63 and car dies. Tapping on ECU fixes it.
  100. P08 s300j ???
  101. tune for new motor?
  102. Stock GSR Tune Help Please..
  103. 92 EG H22A Possible Overheating/Tuning question
  104. Need Help Central Florida
  105. b18c1 gsr wiring and ecu questions
  106. which ecu ?
  107. East/Central Ohio Tuners
  108. s300 tuning questions
  109. How to wire OBD2: not a typical question
  110. Anyway to bypass the VSS with Hondata S300
  111. crank positioning code??
  112. hondata s200 installation
  113. Gauge temp sender
  114. OBD2-A P2E QUESTION
  115. Baseline dyno inside,thoughts/advice request...
  116. new to the tuning side of hondas
  117. JDM GSR Basemap on AEMPro - need help for startup
  118. obd1 pinout 95 integra b18b1 with automatic
  119. Anyone know how to setup a Pocket Romulator?
  120. aem ems h22 crank a tooth signal eratic
  121. obd2 motor harness to obd1 civic
  122. IS p28 USeless until fully chipped?
  123. wiring up launch control
  124. to tune or not?
  125. car is running to rich & smoking black (sohc v)
  126. problem with idle
  127. Unable to boost, check out this Crome ROM
  128. First steps into tuning :|
  129. Who has a "Good" Basemap!!!
  130. hondata s300 burnt up?
  131. AEM EMS
  132. Tuning Diesel Engines (or Diesel EMS)
  133. Anyone else taking EFI 101 temecula july 10-11 and Advanced class
  134. Newbie Honda Questions
  135. p06 code 19(search doesnt use the 19)
  136. Chrome over S100
  137. OBD2A/B question
  138. oem obd1 iacv settings for Motec m4 ?
  139. s300 Boost by Gear MAC solenoid??
  140. omni 3bar map
  141. JDM K20A TUNE
  142. Del Sol Si P28? Is this correct?
  143. Crome/FreeLog Help Needed
  144. where to find maps--Noob
  145. n00b questions: How do you connect your computer to the ecu and J1 jumper pics?
  146. question about Moates Burn2/Crome free 1.5.3
  147. S300 User guide
  148. AEM Uego wideband
  149. Turboedit on windows 7 not working
  150. Tuning and wiring mess
  151. what is the best option for h22
  152. Questions on ECU Simulators...
  153. OBD0 to obd1 problems with check engine light.
  154. Need help with basemap
  155. Can i disable o2 sensor in a chipped P28?
  156. want to get started in Tunning
  157. obd2b motor for my obd1 da teg (i seached!)
  158. b18c map i/h/e
  159. SManager (S300; 1.4.7.0) closed loop question
  160. HELP!! obd1 d16z6 into obd2 96 civic dx
  161. pro EFI?
  162. Simple Neptune RTP question
  163. what motors will a p28 run?
  164. jdm b18c oil sandwich sensors
  165. b16 p28 base map needed
  166. need help with distributor
  167. need advice with aem-ems
  168. how can i get crome to work with vista
  169. Colorado Tuners? - Crome
  170. hondata to chrome?! can i?!?!
  171. what am i overlooking? (m.a.p. problem)
  172. p73 ecu idles high? rpms dont drop to normal
  173. 94 Accord ex stalling issues...
  174. Getting A Strong Tune Without A Dyno
  175. 03 Civic Runs Rough after Hot Soak
  176. Need Help. T.P.S. Malfunction
  177. My tune is running super rich at idle...any easy fixes?
  178. Suggestions needed
  179. basemap for allmotor? i need some opinions
  180. Need some help ASAP.
  181. Where to buy an inexpensive Wideband Gauge?
  182. Need a s300 H22a4 Turbo basemap
  183. trouble with idle
  184. PWM/EBC Ready Ecu's Sold Anywhere?
  185. P30 ECU
  186. Tune/Driveability Question
  187. d16 z6 looking for tuning
  188. BOGS DOWN HARD UNDER LOAD HELP!!??!
  189. switching from crome to ectune, have to retune?
  190. Rough engine/vibration at 45mph
  191. d16y8 with chipped p28
  192. Help S300 wiring
  193. k20a2 swap i need help!!
  194. Re: Tuning Hardware
  195. How to tell ecu
  196. OBD0 Crome DL plugin, or Crome->TurboEdit table conversions?
  197. idle tuning - leaner = higher rpm?
  198. Map Sensor Issue... Supposedly theres a 3 bar installed.. cant find it
  199. obd2 to obd1 need help with passing emissions
  200. 4 plug OBD2 P72-A04???
  201. original basemap F22B DOHC JDM
  202. 96 Civic ECU in a 98 Accord?
  203. good tuner near philly
  204. help set up Boost by Gear s300
  205. 95 honda civic coolant leak Help!
  206. Advancing the dizzy on a boosted motor...
  207. Bad ECU or Bad S300?
  208. ecu question
  209. Anyone located near Nassau Long Island?
  210. AEM EMS Tipin?
  211. fuel injector help
  212. TPS voltage issue on Neptune
  213. Strange engine light/ECU problem
  214. Running extremely rich
  215. apexi safc 2 wiring help
  216. wideband set up
  217. hondta question please help
  218. chip for remapping p28 to d15z1
  219. aem F/IC?
  220. Z6 boosted Tuning issues......
  221. Hondata s100 or Neptune
  222. obd2 injectors on obd1 car
  223. A wiring question
  224. !urgent!..Chipping kit missing pieces. capascitor question
  225. Compatibility of Apexi Power Fc
  226. Looking to get my head built! Need so cal tuner suggestions
  227. DNR vs Blacktrax tuning experiences?
  228. no signal coming from a7, pumps wont prime, whats the problem?
  229. hondata s300 ls turbo
  230. Cant figure out whats wrong with car!!!!!!!!!
  231. how to learn about adjusting fuel values on smanager
  232. code 16; fuel injectors... fixing the problem?
  233. JDM EP3R K20A TUNE FOR AUTOCROSS (KPRO CALIBRATION NEEDED)
  234. Where to get MAC boost solenoid online?
  235. manifold questiion help ???
  236. my car wont start after the swap
  237. Powering an ECU away from car
  238. B20z swap with crower 402s no power down low
  239. D16A6 missfire
  240. how to sync timing in ecu with dizzy?
  241. PR4 ECU on a H22A
  242. ecu
  243. Help, Install Microtech lt8s and does not work the dashboard?
  244. My tuner removed my resistor box on Precision 880s
  245. b20 afr in the 9's need help
  246. obd0 to obd1 harness help
  247. Can i get any pre vtec torque gains with a chipped p28 on my setup
  248. FAQ not working
  249. basemap for h22 with pte 880s
  250. Help/Advice Tuning with VAFC2
