PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. where can i get my ecu chipped in portland oregon
  2. Tuning Hondata with Windows 8
  3. CBR 600 f4i coils help needed
  4. Crome Gold - who is having it?
  5. New Data for DW Injectors and Pumps (Battery Offset Included!)
  6. H23A into 96 Accord automatic ECU NIGHTMARE
  7. do i need california or federal ecu ??
  8. 2004 honda civic OVERHEAT
  9. 1994 Accord
  10. b18 lsvtec pro 1 tune
  11. How to find PGM-FI version
  12. 2nd year of the same problem 01 stock gsr dies when cold
  13. Location of pin 1 on OBD0 plugs
  14. B16A IDLE PROBLEM!!! HELP PLEASE!!
  15. crx surge/fuel? PROBLEM!!
  16. Running race gas?
  17. Making changes in Crome causing limp mode! HELP!!!
  18. Battery Offsets and AFR Consistency (idle/driving)
  19. Need a AEM start up tune
  20. anybody know the OEM JDM B18C1 ECU SPECS???
  21. VAFC question
  22. LC-1 on ectune shooting way lean
  23. afr values for all motor b series how should they look?
  24. immobilizer for obd1 ecu?
  25. AEM question??
  26. How to change internals f22b2
  27. update on what im running if anyone can answer my question.
  28. Advice on choosing a basemap
  29. launch control not working crome help
  30. 2step a b16a
  31. i really need some help with my acura integra
  32. New and need advice
  33. Can a chipped p28 be change to run Neptune?
  34. mtx wideband-factory p72 ecu
  35. obd1 gsr swap problems need help!
  36. Standalone vs factory ecu re-tune
  37. af/r's changed
  38. Anyone near northern indiana for hondata tune?
  39. chipped p72 ecu
  40. question for aem engine management users
  41. G23 N/A base map
  42. Hondata FlashPro Updates & News
  43. vtec help!
  44. Need help identifying this Ecu chip
  45. ECU
  46. Question about Coil-On-Plug ignitions
  47. NEED HELP URGENTLY
  48. B12 OILLIFE 15% (Wrench Light)
  49. TPS ISSUSE?
  50. b18c facing problems..HELP!! :(
  51. NEED YOUR HELP with ECU questions! PIX included!
  52. 1997 honda civic computer resets when car turns off
  53. getting MTX-L wideband to sync with ectune
  54. HELP PLEASE!! Can't get out of limp mode
  55. ecu tune?
  56. not sure whats wrong with my car....
  57. F20B Del Sol Hondata S300 won't go past 3000 rpms while rolling
  58. chipped p28
  59. Need tech help
  60. obd1 and obd2 same time for emissions
  61. NEED PROFESSIONAL AEM TUNER - READY TO PAY
  62. Need help with ID2000's in S300
  63. Which coils for Hondata COP setup
  64. HX vs VX Lean Burn
  65. HELP PLEASE: B18a / B18b question
  66. 93 civic swap need help
  67. low idle and dies. 94 hatch
  68. B20 non-v swapped ek with p72 ecu??? Doesn't sound right
  69. 93 del sol
  70. 1989 crx hf check engine light
  71. b20vtech HELP!!!
  72. Sharing Log files
  73. turbo b18c1 revs to 5k help please
  74. This girl needs advice for S2K
  75. gsr woint rev past 3000
  76. CRX gets spark, pops fuse 14 then won't fire after I replace it?
  77. F20B del sol, turns over but won't start up. HELP!!!
  78. surging engine/voltage problem?
  79. B18 ECU by "Kensports"
  80. Problems with crome on a ls/b16vtec
  81. P06 vtec problem
  82. some advice to start using antilag with s300
  83. ECM questions please help.
  84. Timing belt replacement as well as...?
  85. Idle problem, HELP!
  86. IAT on manifold vs intake tube
  87. DIY wasted spark setup
  88. S300 datalogging questions
  89. K24 ek hatch not starting???
  90. High Idle
  91. B16 Turbo needs a lot of fuel to control knock.
  92. AEM 1050/Jumpers- EPM/Pencil Coils/Twin Fire
  93. b20vtech idle air control valve question
  94. s300 tables
  95. stock gsr looking for better gas mileage
  96. h22 turbo swop civic ek (no spark,injection pulse)
  97. OBD2a to OBD2b
  98. Converting Help!!Trying to BAR obd2 JDM ITR in a 93 eg6
  99. Considering Building This, Need Suggestions
  100. AEM Issues:(
  101. ecu not communicating with OBDII
  102. will a corrupt map cause...
  103. ems 1050 t1 trigger, k20 coils problem
  104. JRSC and Ignition Timing? MAP sensor?
  105. K series ECU
  106. obd2 civic vss wiring to ecu - which pin?
  107. B18B1 lumpy/rough idle
  108. po6 ecu acting up please help
  109. What is noise?
  110. Haltech Platinum Sport 1000 vs s300
  111. P28 ecu, VTP always on?
  112. 01 accord sedan AC clutch wont engage.
  113. aem ems v2 vss problem 07 civic si
  114. i need a base map for my ls vtec
  115. 01 accord sedan AC wont work!!!
  116. Anyone have any stock J32 aem basemaps/tunes?
  117. AEM Twin Fire 30-2821
  118. How to wire tach with cop and t1 trigger?
  119. k20a2 Type S engine harness on F20c s2000 engine?
  120. 91 ef2 JDM D16A CEL wont go away
  121. a/f numbers dont match
  122. Need some UPDATED info, need a good dyno tuner in SAN DIEGO!!!
  123. Help with idle problem 1990 Civic
  124. Strange wire near exhaust!? Please help
  125. B16 Turbo Breaking up Under load Neptune
  126. k20 intake manifold on b series
  127. Looking For Engine Swap Shop In SC??
  128. tune help d16
  129. Excessive electrical interference during tune
  130. Wont crank over
  131. New Flex Fuel Sensor Support Added To Hondata S300
  132. 93 civic d16a swap!!!
  133. 93 civic ex d16a swap
  134. LC1 Wideband Error code 2
  135. Fuel system/ bigger!! Will I need to get it retune?
  136. Increase in Air flow- more or less power?
  137. apexi safc2 wiring help
  138. timing/retard for boost
  139. Chipped p28 wont see external chip & uses onboard map
  140. Xenocron.com Write-Up - DIY Install of Innovate, PLX or AEM Wideband to an EMS
  141. Non Ethanol Gasoline
  142. Map pressure question possible intake restriction???
  143. Tuned on E85, relocated, no e85 stations!!!! Help!!
  144. wideband egrl or eld? whats better?
  145. Useful Feature In Latest Hondata Software KPro/FlashPro/S300
  146. This freaks me out. ECU Ignition Adjustments
  147. noob question about widebands
  148. change the downpipe require a retune
  149. Different ls ecu's???
  150. How to upgrade B16A2 engine
  151. header removal...question
  152. tuning P28 automatic obd 1 ecu?
  153. so lost...HELP
  154. Basemap Timing/Retard - LSVtec Turbo 12psi
  155. Moates Demon.... Freeware
  156. "safe" rev limiter question
  157. B20 & ObdO
  158. question to the wise about neptune
  159. AEM SER 2 OBD2A (6060) COP k series coils .
  160. PLX multi gauge wideband 02 VS AEM Wideband
  161. b18c turbo valves Compression
  162. [s300] Normally open boost solenoid: Pressure vs Duty cycle
  163. Hondata s300
  164. Intake Bypass Valve
  165. d16z6 distributor
  166. crome issue running fine on ostrich once burned to chip sputters
  167. P1508 replaced sensor still there
  168. Rich after vtec until car is restarted; CROME
  169. Where can I get a 0 ohm jumper?
  170. 24 Hour of Lemons with P72
  171. Which spark plug B18B?
  172. P28 ecu/limp mode problem
  173. California Emissions Question... Please help: Smog tomorrow again
  174. Cranking power source
  175. Basic tuning question
  176. aem ems w/ stock distributor question
  177. S300 - 1600cc & Omni 4-Bar MAP base map
  178. Aem serial logging
  179. b20 idle problem
  180. tps and mil light
  181. placement of the IAT sensor
  182. Question for OBD2A to OBD1 step down harness
  183. crome pro o2 voltage fluctuation and p72 wont log with j12 removed
  184. Aem 1040, cam trigger, help needed!!
  185. First Gen JDM B16A Ticking Noise
  186. OBD1 ECU D5 Replacement Diode
  187. OEM ECU fueling issues
  188. Do I need to change my coolant?
  189. Car began to sputter at high rpms as it was getting tuned on dyno..need help
  190. F22b1 Turbo Basemap
  191. Crome datalogging fail Cant
  192. SO CAL TUNING
  193. Scam
  194. Innovative LC1 Wideband question
  195. Funky S300 tps calibrating
  196. Mods Causing Damage?
  197. Failed smog check 1995 Prelude
  198. Chipped P28 runs fine, then solid cel
  199. Redo Stock Harness to stand alone
  200. Crome and "Real Time Programming"
  201. EGR at idle ???
  202. Self Tune?
  203. Megasquirt 3
  204. Dead Demon?
  205. Motor dies out when tuning on idle?
  206. Diagnosis and Tuning by Laptop
  207. aem rev limiter settings, lean
  208. D15b7 Vtech mini-me Head swap
  209. b16 code 8 issues
  210. What Interface?
  211. Setting base ignition timing?
  212. What are my tuning options?
  213. eCtune EBC Fast Spool Issue
  214. So Is my car OBD1 or 2 now?
  215. speed correction s300, not changing speedometer...
  216. tuning equipment
  217. Why not s200 no more
  218. D15B7 1992-1995 injector and hondata s300 question
  219. AEM EMS/ 3.5bar Map Problems...
  220. ecu chip question
  221. wideband O2
  222. B18B-T low throttle / swinging AFR issues
  223. ignition timing and injector tables tuning questions
  224. fuel economy tune
  225. OBD2 - Clutch Switch
  226. intake length tuning.
  227. tuning/ecu questions
  228. tried to remove pin from ecu connect...
  229. Precision dead times
  230. accord on a s300.
  231. Wierd cel issue, obd0 to obd1
  232. Plug and play resistor help
  233. no start/spark/rpm with neptune, will start will stock ecu
  234. help with aem epm civic drag car
  235. JDM H22a in '92 Prelude question
  236. hondata coil pack retrofit cpr help
  237. B16 stock injectors 8,000 rpm at max duty cycle?
  238. datalog wideband with crome using eld port??
  239. EPROM and Emulator questions
  240. Code 43 help
  241. F20B swap help!
  242. 95 accord driving cluster
  243. TDC, CYP and CAS
  244. Miss fire at high rpm's
  245. using B5 connection with s300
  246. wanted h22 harness
  247. apexi vafc problem.. please help
  248. Code 8 Integra
  249. AEM EMS - how to troubleshoot cam trigger
  250. LC-1 wired to eld loses voltage. Help!!!
