Analysis: Is this OBD1 P75 ECU stock or was it modified to accept Crome?
Okay so I bought this ecu from a guy for $100 said it was chipped and tuned on crome. But this **** looks stock to me I'm not an expert on ecus by any means but I don't see any difference from a stock p75 to this one. Any help would be appreciated.
re: Analysis: Is this OBD1 P75 ECU stock or was it modified to accept Crome?
Stock. Bad news, your friend is full of it. Good news, no one fucked it up yet so it’s a good candidate for an S300 install. Solder away.
Not chipped... not tuned on CRomE. Stock... and still worth a Hondo.
Okay thanks so I talked to him and he said that he was overseas serving our great country. When he came back he took it to a shop and said they tuned it he said he wasnt sure if it was remapped or chipped but I never even knew you could remap the ecu without chipping it. Did the tune shop he went to bs him?
You can't. It's a stock ecu. Doesn't matter anyway, if it was tuned is his car it wouldn't be in your car, unless you got his engine too.
Yep I got the engine as well b20b built head cams, valve spring, retainers he said it pulled hard
O.G. triple O.G.
