PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32
  1. AEM Logging...
  2. Crome tuned...
  3. ecu help
  4. d16y5 tuning help
  5. Anyone Know why my d16y8 is overheating?
  6. s300 questions
  7. code 9 on my s300
  8. HiResP72ll rom for crome
  9. Changing from 880 to 440's injectors
  10. 1st time tuning on dyno. w/b only
  11. Ignition question???
  12. Aem wideband???
  13. Will a p72 work
  14. need a tuner in dfw area.
  15. hondata ?
  16. what other tune can i get besides hondata?
  17. Need a stock bin file for 89 PM6
  18. hondadata shit light question
  19. Chipping usdm and jdm
  20. car runs like crap after switching to pr3 ecu
  21. need help please
  22. need help with 88 hatch
  23. P28 adding IAB. Some question...
  24. 5 volt ecu modification (for wideband users)
  25. AEM Wideband for operating in closed loop?
  26. with cruise on car is constantly surging
  27. Lost on obd0 to obd1......also hondata/zdyne
  28. sanity check please
  29. Non USDM GD3 MT with KWSC kit. Help please
  30. TUNERS IN CHI TOWN?????????????
  31. ECU Bare Essentials
  32. Need a GSR cal.
  33. need help with basemap before start up
  34. obd1 crome p73 ITR style map?
  35. Recommendations for reman cylinder heads
  36. I need a jdm b16a motor basemap
  37. which ecu can i run!! need help asap
  38. egr code p0401
  39. Chipping, socketing, jumping?
  40. hitting boost cut or a cut in third gear?!?
  41. Whats your opinion on Oil?
  42. ECU???
  43. anyone know what's up with redzone performance?
  44. Integra B18A1 help needed
  45. Replacing Valve Cover Gasket On Honda Passport
  46. obd2-obd1+ cat delete
  47. B20 VTEC Fresh Build on base map (Incredibly Rich)
  48. d16z6 turbo idle issue
  49. Hondata - changing RPM and Load Indexes
  50. Hondata vs. etc. etc.
  51. Will Valve adjustment affect AFR?
  52. Question about Actual Timing versus Table Timing
  53. What Bin to use to pass smog?
  54. moates 2timer what is the purpose?
  55. Can I use my Hondata calibrations on neptune?
  56. need help wiring my lc1with my db gauge to s300
  57. Datalogging with crome
  58. Zeitronix Data Logger
  59. s300 question
  60. Dynos with Tuner Appointements in Las Vegas?
  61. ICM SCHEMATIC
  62. Need to tune high cam map under vtec engagement point?
  63. d16y8 with p06
  64. Igniter RPM Output
  65. 114 octane to E85 making the switch.
  66. turbo b16 looses power at 6000rpm's
  67. first swap need help!
  68. please help!! eg wont start
  69. JDM ITR ECU help
  70. OBD2B ECU
  71. First time tuning...input needed on ignition timing
  72. Manual ECU in Auto Car?
  73. Q3 Burned on P72
  74. Chipped P06 Ecu question
  75. CEL as soon as VTEC engages
  76. chipped p28 solid CEL without J1
  77. please check my stock d16y8 turbo crome bin =)
  78. PLX wideband oxygen sensor part number type b square plug
  79. i need help for a turbo plzzzzzzzzzzzz????
  80. 1991 honda accord EX no spark
  81. p61 ?
  82. What is the purpose of Tunerview
  83. 2001 s2k floods cold
  84. B7/A6 basemap?
  85. ECU debate
  86. How many people leave tuned cars in open loop?
  87. Whats all the hype with tuning hondas?
  88. Degreeing cams
  89. S300 question
  90. chipped ecu with eCtune + Cn2 port cost???
  91. Timing ? Pressure in system
  92. Timing Light Question
  93. IACV/EACV- Stuck in cold weather mode?
  94. crome won't open a BIN file
  95. h22 type s vs h23 vtec
  96. what ecu do i use for the h23a blue op
  97. ODB2 Scanners & Repair Database
  98. running a little leaner in 1st and 2nd gear, honestly how bad is it?
  99. Go with s200 or stick with crome
  100. i need a jdm ITR tune map if anybody
  101. help!!! b20 vtec pls
  102. JRSC 11 PSI High Boost Pulley for ITR ?????
  103. ITB Tools Settings Thread
  104. Weird noise from Integra Engine
  105. How far can I push a H22A????
  106. Best tuners in CHICAGO.
  107. JET Performance ECU reflash
  108. My tuning setup plan.
  109. no r54 on a P75 ECU?
  110. D16Y8: How to read/display Knock Sensor information
  111. tuners need help on which wideband to buy
  112. S2000 Standalone Engine Harness
  113. can anyone steet tune near owensboro ky...north west ky
  114. ITB and CROME questions
  115. video inside: sometimes runs rich after shifting. FIXES ITSELF IN 5TH GEAR?
  116. need zdyne sftware asap
  117. H22A Computer Problems, AEM a fix?
  118. Need help with chipped ecu
  119. Looking for someone to street tune Hondata S300 near se PA one night this week!
  120. Accel Dfi advice/ help??
  121. possible to bypass/eliminate speed sensor code obd1 ecu???
  122. EMANAGE AUTOTUNE HELP
  123. Lean Idle at startup idle.
  124. S300 not starting car
  125. b16a2 81.5 do i need to sleeve
  126. JDM D1B Vtec, very rich, crome
  127. diffirent fuel man and ignition in P39 and P5L
  128. how could you tell how many cc are injectors and what kind are they????
  129. Hondata s100 red LED light not coming on..
  130. emanage ultimate tuning JRSC b18b
  131. emanage, b18b, car wont start
  132. Best tips for maintaining car engine
  133. how far must the wideband go into exht.
  134. please any info high compression 13.1 +turbo octane enough?
  135. 89 civic car wont start, plzz help
  136. emanage ultimate software no b18b?
  137. Maximum timing?
  138. VAFC Problems, please help
  139. Neptune TPS Problem need help
  140. Mild build Turbo D16Y7 or Mild Build Y7/Z6 Vtec Head?
  141. Manual switch for datalog
  142. Turboedit Problems
  143. ECU help. unwanted resetting at high rpms
  144. My Project Car:Need Suggestion
  145. What brand laptops work better with s300?
  146. Honda Accord 2007 V4 Sedan not turning on
  147. resetting vafc 2
  148. aem ems 30-1020/epm/twinfire/aem coils ???
  149. UGEO +factory O2
  150. Nashville area fuel injector servicing?
  151. what chip i should buy
  152. TunverViewII parameters to monitor?
  153. Need help. i dont know what this is
  154. Anyone using chrome? Opinions on it please!?!
  155. Code 20 ELD Possible Work Around?
  156. just wondering about some chips.
  157. what are the best tuning shops in so-cal?
  158. getting OBDI car to hook up to OBDII emissions
  159. can i chip d16y7
  160. repairing an s200 (P.S. hondata sucks)
  161. "98 accord with F23A1 random misfire
  162. single wire 02 sensor ? (EG)
  163. Mitsubishi distributor, nissan ignition box B-series engine
  164. need Helpppppppp
  165. Stock P28 ecu from ebay pops cap, recourse?
  166. hondata s300 basemap for d16y8
  167. b18c1 into a 92 civic si - which ecu?
  168. bad obd1 ecu?
  169. S300 plus FJO nitrous controller
  170. 91 integra (auto) car wont start
  171. tuning with aem ems
  172. Need some advise Hondata
  173. smanager w/ Wideband
  174. which ecu works?
  175. Hondata s300
  176. who can talk about afr and ignition from pics of spark plugs?
  177. s300 question
  178. tuning d16 turbo with crome free
  179. What Tuning software is this? Pics inside
  180. hondata s300 datalog problem
  181. Need some help with ZC non-vtec P27 ecu
  182. Best Tuner?
  183. looking for someone to tune my car
  184. hondata s300 closed loop open loop questions
  185. how accurate are s300 base maps?
  186. crome says recording but cant find anything recorded
  187. Stock p28
  188. 2000 GSR in my EK running rich
  189. type r bottom gsr head tuning ?'s
  190. hondata S300 red light in ecu?
  191. need some help with my basemap or has one that will work
  192. Engine upgrade
  193. Is this Ecu Socketed/ Chipped?
  194. need a basemap please for gm 3 bar with 750cc
  195. S300 Problems!!!
  196. can i ask of your knownlege
  197. Fuel Percent Change Issue. idle af all over / S300
  198. Anyone have a 37820-P75-A01 for sale
  199. Problem using DSM injectors with Crome
  200. Hondata S200 System Questions 2010
  201. VAFC ReVisited
  202. Microtech Lt-10
  203. 1993 Honda Civic EX ECU Issue
  204. 95 Honda fuel smell please help!!!
  205. need help with mini me
  206. 2step hep needed
  207. air fuel ratio help
  208. Really Need Crome Help...I've Tried Everything!
  209. valve cover replacement
  210. B18CR rywire harness to OBD0-OBD1
  211. I need a crome basemap!
  212. crome vs ectune
  213. help me pls lol ples read
  214. Help: Super Rich/Idle issue
  215. power fc tunners
  216. need map on aem ems sreies 1 for my 03 s2000
  217. Higher compression on Stock LS ECU??
  218. crome and distributor timing
  219. Wiring mess
  220. need help my civic turbo gettin too hot this is the spec
  221. Target lambda on E85 (Cruise, Idle and Boost)
  222. how to chip a p28
  223. Dynojet setup help...dyno operators please chim in
  224. gettings valves redone?
  225. WTB: Complete EK Coupe motor A.S.A.P!!
  226. P28 Fuel Pump not priming need some help!
  227. P28 Issue, Repairable?
  228. need help identifying if p06 is conv for vtec
  229. help! over revved my h22 to 10k rmp
  230. S2000 Cluster and AEM EMS 2
  231. Car feels weaker after tune, too much timing?
  232. tunning help!
  233. GSR basemap/ CRome = Solid CEL
  234. Emissons for California
  235. JDM CAI Help
  236. T1 cam trigger and ls1 coils on a Honda??
  237. overheating problem on a da9
  238. D16A1 ECU
  239. S300/wiring Issues
  240. EFI University
  241. Megasquirt question
  242. Ecu dummy
  243. Anybody heard of Rich Tuned?
  244. basic ecu question... easy
  245. moates ostrich 2.0...
  246. can someone make me a s300 tune
  247. Good/Bad results from a P06 convert to Vtec w/custom chip
  248. Hondata s200 pinouts - need help
  249. How to socket/chip a jdm p30 (tried searching)
  250. problem with h22 eg
