- anyone in Mi. that can tune Neptune RTP?
- Any advice on buying ecu with second hand s200 set up
- Hondata - Tuning W/ TPS Eliminated
- b20 basemap please?
- Square peg round hole (correct zif socket needed?)
- vc-3e on pr4
- tranny
- s300 hp reading
- best rpm to set vtec at on a typer p28?
- moates burn2 problems ! CROME 1.5.3
- crome on windows7?
- speed limiter on a pr3 ecu
- Wiring up CEL and low Fuel Lights
- Newbie when it comes to chip ecu?
- need help tuning!
- anyone familar with the aemems particuarly with the e.p.m c.o.p.
- Chipped P28 ECU throwing a code 19?!? (A/T lock-up control solenoid)
- p08 chip for a p28
- has anyone tuned a b16 with bolt on's?
- DIFFERNT ECU MAKE UPGRADE TO PERFORMANCE??
- need help with tuning
- PLX Wideband: Need wiring advice.
- crome tuning
- installed my 3 bar but ran like crap
- S100 installed, what do I need to reburn??
- Nokia datalogging cable (DKU-5) colours and pinouts for datalogging?
- jumper harness question
- OBD 1 Hondata S300 A12 FANC triggering randomly.
- apexi afc neo questions
- coil on plugs - haltech ECU setup
- Rich AFTER boost in vacuum
- Will an OBD2B P2P ecu and harness run a JDM OBD2 D15B??
- Comparision: I cant decide between these 2 options - HELP!
- V-AFC Question Please.
- AEM wideband w/ S300
- PR3 ECU details in question
- Wiring Datalogger for S300
- Kpro problem
- Code 22
- hondata problems/CEL issues
- fuel management/correction issues
- s300 launch control question
- .skl to .bin converter?
- Obd1 vtec ecu chip kit install
- GSR Exhaust Questions********
- wanna buy chrome
- Require re-tune after auto-manual swap?
- S300 Tunning Problems
- code 61 '00 civic si
- Hondata s100 question
- A couple ?'s about eCtune
- Adding Analog sensor to S300
- bare minimum
- crome not responding in real-time
- California State Ref ticket
- Tuners in the 417/missouri area?
- Need a ls/vtec base map
- unleaded gasoline vs E85!!!!
- Exhaust back pressure
- CEL code 67, cat converter, help
- How to read CEL, 99 EM1
- Please advise on my AFR.
- Aem Uego wideband problem
- need ecu pins
- Vtec head on D16Y7?
- Code 10 and 14
- ecu help
- Code 20 (ELD) 89 crx OBD 1 conversion
- t-1 with haltech e6x
- VAFC 2 11:1 b18a tuning questions
- B18c type r wont rev up
- Where can I buy an OBD2b connector?
- base map compare
- s300 tuning
- Injector Question?
- boost cut??? don't know...
- Ecu problems. please help
- D15b engine HELP!!!!!!!
- S200 with boost? How to tell?
- anyone hear about this new training school for tuning? Thoughts?
- P72 on a type r
- d16y8 complete engine
- s300 problem red light flashing
- Crome/Freelog ridiculous readings __!__
- Hondata s300 boost control?
- SUCKED WATER INTO MY COLD AIR INTAKE..RUINED?
- tuning software ? been out of the game for a while..
- Where can I find a H22A basemap with EGR and Knock disabled?
- cold air intake VS ITB
- AEM or Hondata S300?????
- car misfires and bogs with s300
- 92 Accord LX Speedometer Problems.
- obd0 PR4 conversion
- EF D16Y7, need help!!
- How to install a timing belt on a D16Y7?
- RTP injector
- Jdm gsr ecu in a usdm gsr motor..
- Engine idle at 1500, and bounces; CEL on (w/ VIDEO) ideas?
- What ecu can go with h22A.,.,??
- s300 will not restart after car has been running and warmed up.
- Does this ecu look ok?
- ***making b20vtec...
- car falls on face
- Blown Headgasket?
- AEM UEGO, Display or Voltage Output?
- Alpha-N mapping with CROME
- Anyone know exactly which parts are used for VTEC conversions?
- Check engine light..
- P28 vs P06: Any advantages for Hondata?
- Color of wires for obd2a integra gsr..trying to hok up vtec controller
- why is my check engine light on?
- '02 Odyssey Misterious Missfire, Help
- Need some help with this ZDYNE
- dsm injectr questions wit hacked afc2
- 95 Accord 2.2 Random Idle Misfire and accelleration bog
- How can you tell a P05 board from a P06?
- AEM COI Ready for Install
- New NepTune RTP Release (OnBoard Logging, Anti-Theft, and MORE!)
- B16 turbo with wierd High cam issues ( Tuners please evaluate)
- Dyno in Oregon?
- Differences In Programs
- installing 4 pin header
- choice of Wideband
- 2 cylinder misfire-97 accord vtech 4cyl
- Questions about converting to Hall effect type sensor for cam/crank positions
- D16Z6 Engine w/ P30 ECU??
- Which Hondata S-series is Best for Me?
- OBD2 scanner software for PC
- (#2)How much Boost can a stock H22 handle??
- b20vtec tune
- How much Boost can a stock H22 handle??
- '95 Integra RS with JDM B18B runs fine with P06 but not P75?
- Hondata S300 overkill for me?
- Individual cylinder tuning
- Car came With Tune...Need Help
- B&M Fuel Pressure gauge
- Check Engine Light + Cold Weather?
- What do I need to tune? New to EFI... Help is appreciated!
- p30 on a SOHC??
- Fuel/Timing maps and Power vs. Biofuels
- Tuned h22a on Crome.
- Voltage
- D16y5 turbo Map
- b20b base map
- S300 box contents
- WHAT DO I NEED TO TUNE A CAR?
- Just chipped first ecu with blank SST27sf512
- p75 or chipped ecu
- CEL problems
- Tips for a road tune?
- WTF do i do now?
- b18b1 turbo eg. ecu not chipped or tuned. ?
- what would you do?
- Blew engine block
- s300 h22 basemap, too rich.
- ECU is dead...s300 or ecu problem?
- need help with m&w pro 10
- bad MAP cause s100 limp mode?
- why use a fmu?? vs mail order basemap??
- innovate wideband cutting out...
- peformance chip?
- plx m300 hondata not reading below 11.9
- Swap help please
- xenocron and other gm 'style' 4bar sensors.
- hi, need help p28 ecu auto
- Using Fuel Cut vs Ignition Cut
- putting injector resistor box on p30?
- Converting a L15A VTEC to an aircraft engine
- IAT sensor locations
- track tuning
- chipped p28 ecu question
- self tune
- main bearing identification
- homemade rtp/solder eprom burner to ecu
- Car continuosly turns off
- car bogs when in 4th and 5th gear please help?
- No VSS need to retune help!
- AEM 1040 Standalone Map
- Civic EK - 1.4 swap to....
- H22a cruise
- hondata s100 for m turbo build?
- AFR Change to lean or rich on low cam(h2b bosch725cc)
- Need A Custom P72 Basemap
- no-tune turbo...
- Chipped PR4, Big Time problems, PLEASE help
- upgrading map sensors in crome
- Chipped ecu questions
- Crome tuning: Opinions?
- Proper Engine temp.
- air temp sensor bypass.
- DTA users/tuners in Boston area?
- Can vtec be disabled in a P28 ecu?
- SAFC-tuned GSR, still leans out.
- chipped ecu help
- Need tuning in Fresno CA
- tuning obd 2...00 si with ls/vtec
- hondata s300 alternative?
- Crome Advanced Maps FAQ/PDF, etc.
- Non-Honda management questions.... FC Datalogit
- tensioner problems fml
- Odd Question Re: ECUs
- GM 3bar problems
- Spare ecu
- Is this a p28??
- what ecu to use with hondata and non vtec f23?
- jdm or usdm p72 ecu for b20vtec?
- full sized radiator for ej6
- p75
- itbs with s300
- Demon and datalogging? No issues, just questions.
- HELp EX head swap with my HX
- Thumbs up for Evans Tuning in PA
- automatic prelude tuning help
- S2000 running rich....solutions/ideas?
- How much difference? ecu chipped
- Need a "C" harness plug - OBDI prelude
- Ostrich version 1
- 1st gear for vtec not working on 96 gsr
- can any one help?
- JDM h22a swap help!
- Suja 1 Motoring
- s300 and obd0 injectors
- New to EGT, is this safe?
- send obd0 pr3 away to have tuned??
- SMOKEY
- s300 HELP!!!
- s300 HELP!!!
- Performance Chip/Module
- wb o2 running the stock o2 senor
- obd1 conversion
- ECU???
- newbie tune question
- (mostly) stock rebuild..do i need to tune?
- ecu help
- opinions on best OBD0 editor?
- spark plug gap and tuning question
- Can a re-tune wait?
- ectune ?'s
- Reputable tuning dyno shops
- Increse fuel pressure, better atomization??
- Solid CEL, no key on blink...
- OBD1 JDM P72 Auto to manual
- Speepometer Signal Interface H22A Automatic
- Will a 1990 PM5 ECU run a DOHC-ZC??????
- How much more HP?
- White Smoke
- Can't data log when vtec is engaged! EcuControl
- Intronics A2 Rom Emulator w/Crome?
- s300 jdm p30 calibration question
- Crome issue?
