- ECU questions
- My first basemap h22
- My first basempa h22
- On my way to Whitfield Racing to get tuned!
- RedZone performance Fremont CA??? What happen?
- switching honda maps with pin d2/brake switch
- almost 2012 whats the new stuff for engine management?
- Engine mounts & bushings
- Driving in Cold Weather
- R53 on the OBD1 ECU board
- up to date tuner northern florida
- ID 1600cc injector recall??
- Need a basemap for Hondata s300
- k24a4 ehaust
- Neptune PA Atmosheric sensor
- P13 ECU Pin Signal Types
- OBD2 To OBD1, few questions
- cel problems
- Neptune RTP maps
- water temp & idle
- jdm p72 ecu chip and tuning questions
- P28 Hondata question.
- half a wide band lol
- hondata s300 losing p30 basemap?
- P28 ECU to OBD2B
- voltage correction in neptune
- outdated aem 30-1000
- racepak iq3 with aem ems
- tuning for mpg
- need help with obd0 ecu chip
- hondata s300 no usb reading ??
- wireing harness help needed.
- neptune rtp, switching to stock p72 maps?
- Is it a tuning issue? (car stalls out after turbo install)
- BASEMAP VS. APEXI NEO TURBO REX
- 92-95 civic harness needed
- revo set at 7500 on s300 car wont go past 6800
- Need a good tune
- Ecu question
- Best street tuning methods
- aem tuner needed in wa state
- Virgin p28 on B18c
- Need MSD Ignition
- 2003 Accord ABS Light
- Idle Problem with HONDATA S300
- E85 cranking fuel percentage
- CAR HAS PROBLEM STARTING
- Convert JDM p72 auto to manual ECU??
- b series engline loom diagram
- tuner help
- How do i post kpro datalogs?
- Crome gold events
- Neptune & PTE 780cc Injectors
- Help with Kpro and other issues , K20/EM2 datalogs inside
- Warning - S300 counterfeits
- MD emissions problems! ECU HELP!
- VTEC PRESSURE SWITCH BYPASS BUT STILL HAVE CEL?
- what engine management system are you using
- Crome 1.6.2 Datalogging
- Tunerview II with S300 question
- HIGH idle only at first start-up!
- PLX DM-6 question
- innovate mtx-l wideband help
- Honda CRV 2004 O2 Sensor replacement
- greddy e-manage Q....
- In need of a WORKING KAL!
- obd1 to obd2a harness issue with s300
- USDM B20Z Emissions Test Results (TX), Phearable basemap.
- missfire or no fuel or......
- thinking about buying a Honda HDS. worth it?
- Losing fuel pump or Injector 12v on boost.
- Fuel Injector Miss Fire !
- RC SL750cc Injector Dead Time Settings In S300
- d15 engine rebuild or diff engine swap??
- O2 SENSER DELETE HOW TOO
- Changing injectors
- H22 turbo S300 - cold start
- K-Pro Counterfeit warning
- vtec crossover too high??
- Ostich 2.0
- cold start/idle issues AEM V2
- turbo or supercharger an what kind of EMS for a fully built H22 click for specs on mo
- Apexi PFC - Detonating/Knock after install
- My V6 accord powered sandrail project
- is there any way to do a fuel and ignition cut on crome gold?
- s300 basemap take a look on these setting(gsr turbo)
- HELP: AEM EMS v2, epm, twin fire, cop...
- B18C5 injector problem
- Crome Update Advisor - Help Me Disable This.
- p28 with an auto trans and tcu
- Does anyone have a better why to reach Hondata for Tech help?
- Wideband 02 sensor life?
- Honda Ignition timing adjustments ????
- b18c1 distrubutor re-pin odb1 to odb0
- p28 s300 long question
- need a map ASAP
- Belt or Chain
- Spark Plug reading
- Rescaling map for new MAP sensor without retune? Neptune
- 37* BTDC On Stock Integra LS
- 2003 Accord P2646 code and ABS light
- Crome GOLD Map: Editing High Cam RPM to Match p72
- WHATS BETTER AEM or KPRO for K-SERIES
- p72 ecu help
- H22 Igniton timing Low cam Tune request!
- Soft Rev. Limiter. How to fix with S300 ?
- the purple square with crome question?
- Crome Free Anti Lag On p72 Code Base??
- anyone have a DYNO FS?
- Glowshift vs. Prosport gauges
- can u identify this chip?
- Subaru Impreza Turbo boost solenoid in Neptune
- What's a good Accelerometer/Exhaust temp gauge?
- Hondata s300 HELP, Need help with IDLE please! Have a video!
- chrome on a DD
- Special thanks to AEM! Bisimoto beta test of prototype DBW 83mm throttle body video
- turbo fuel adjustment question
- Very strange problem hesitates as crossing over into v-tec, vid inside, please help!!
- aem t1 trigger and cop help
- which air fuel ratio meter to get for tuning purposes?
- How to check CEL for OBD0 ecu?
- Emissions Dummy ECU
- aem uego and s300 problems
- H22 Compression problems?
- NepTune
- Need your Emanage suggestions
- OBD0 and TurboEdit 3.2.2 - My 90 CRX and OBD0 B18A1
- chipped ecu help
- what are some little ways to improve the torque on my 1992 honda civic sedan?
- Hondata/Tablet question
- Piston ring placement (d-series)
- H22 Ignition timing (Low, medium, hi) load
- Re manufactured hondata?
- hondata s200 cuts off at 4,000 rpm. need help
- CEL works but does not illuminate for code 20
- Last bit of wiring on my k20 em2, LAMBDA SENSOR
- precision 1000cc tuning variables s300
- help for my d16a9 setup.
- reading spark plugs
- 92-00 Swap Wiring Guide for VTEC and Non-VTEC
- 02+ rsx factory wideband in older car?
- K20A2 KPRO Idleing high
- Tuning Classes
- built b16 low power help!
- Stuck in corn with 200hp HELP!
- type s ecu with k20a type r motor?
- OEM P73 Pistons with Pin Locks! How?
- quick ecu question/suggestions
- USB port on ECU/S300 not connecting
- Hondata s300/ecu issue
- 10W-60 oil bad for B16A2?
- eCtune ecu "found" but no data will display.
- J35A swap and smog
- map scaler + injector voltage
- Need To Overnight Chip Burner To Canada Suggestions???
- About JDM P72 obd1
- High altitude tuning question
- H22a4 problems no vtec
- b16a all motor question?!?
- Tuners in N.E. AR
- VAFC on D16y8 w/ p28
- aem ems help
- aem ems need some help
- Will a bad PCV be detectable at the sniffer?
- To wideband or not to wideband?
- need help!! been tryng for 2 months!
- b16b ecu help needed !!!!!
- ostrich 2.0 and solid cel
- High Compression B16 E85 Basemap & 91 Octane map, Help?
- Retarded CEL
- Any tips and tricks on tuning timing on S300?
- OBD1 P72 ECU - O2 heater circuit burned up - repair?
- no response from the gas pedal
- how to hook up innovative lc-1 wideband
- S300 ITR basemap...
- pulstar spark plugs?
- B20/B16 ECU/
- Electrical Short
- crome pro woes
- Wideband sweeps to very rich between shifts
- Greddy E-Manage Ultimate - Help
- Injector Battery Voltage Compensation
- All Chipped ECU created EQUAL??????
- help trying to self tune my lsvtec turbo
- trying to pass emissions
- Help 99 ek coupe swap
- Running B16b with an ITR basemap, safe?
- JDM 37820-P72-901 4pin question...
- Hondata Tuning Software Intercompatibility
- H22 problems no vtec!!
- WTB: K20A ECU from CL7 Euro-R (RBC)
- Hondata S300 GSR cams
- hondata s300 p28 green light on NO start
- b16a2 Tuned Afr ideal.
- Microtech Lt8s fit on obd0?
- Anyone have P08-N51 stock bin?
- HELP! 92 prelude s swapped to h22a4
- HELP WITH HARNESS?? 92 prelude
- Newb question...How is timing physicly advanced?
- chip program recommendations for my current setup
- code 10 trouble out of ideas/ boosted b16
- H22 Low cam fuel smoothing request/help
- 2008 civic low idle
- how do you convert o2 voltage to a/f ratio?
- Evap Purge Control Solenoid Question
- s300 in po6/ vtec will no work
- h22 loosing spark @ high rpm
- Ultra rich tip in (Turbo Integra)
- Tach needle goes haywire after 5000 RPMS
- tuning around indianapolis area?
- Looking for aem ems v2 info
- EMS-4 Universal
- B20vtec supercharged map anyone?
- obd2-obd1
- Tuning the Singer Porsche Motor at Cosworth – Why Engine Dynos Matter.
- What are you guys using with no carpet to protect your ECU?
- 95 del sol turbo tune
- error codes
- 4bar Map Sensor!!
- crazy high air intake temps
- VTEC pressure switch
- What are good target AFRs
- Problom S300
- p28 noob
- Innovate MTX-L losing calibration
- Ems2, TwinFire, EPM, COP second cylinder dead!
- Boosted setup running rich and cutting out
- Very tocuhy gas pedal problem
- P30 Chip
- WTB: aem series 1
- no power under boost, shitty idle, arm fic HELP
- solid cel on chipped ecu
- Neptune RTP injectors wont spray!?
- Goal: Tune my own car...Noob at this
- Help with my speedometer. P06 ECU
- Can i alternate between two diff. tuned Ecu's ?
- Q31 HELP fried h22 turbo
- Map?
- Innovate LC-1 install, having troubles! help appreciated
- Did I wire my MTX-L & TunerView safely?
- cannot get 1000cc to idle smooth ? ive searched
- Tuning chipped P28 ecu?
- flashpro not connecting to ecu
- 1985 honda prelude help
- ecu with burnt q31
- P28 Resistor 77 color code
- D16a8 HGF
- Tuners Experience with high boost D16z6 & Hondata S300... ignition timing
- s300 with boost controll
- BRE tuner
