wideband O2 sensor choosing
Old Oct 28, 2019 | 07:18 PM
Brembomaster's Avatar
Default wideband O2 sensor choosing
Hello,
I would like buy a set air fuel ratio gauge,
anybody know what are different with innovate LC-1 and LC-2? does it work on B18c eg with wire to OBD1 ECU hardness ??
I also has P28 chip ecu and power fc, does it read the widebands snesors if i wire to ECU?
Thanks
Old Oct 29, 2019 | 03:12 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: wideband O2 sensor choosing
go with AEM UEGO instead.
Old Oct 29, 2019 | 04:23 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
I’ve ran aem widebands for the last ten years and they do very well for me. Sensors can be bought at most auto parts stores if a replacement is needed and they are very easy to setup and install. I’ve had innovate widebands which had a constant e8 error code regardless of having a new sensor or not, I’ve used a glow shift wideband and it would read anywhere from 1 to 2 afr full points off.
Old Oct 7, 2021 | 02:36 PM
Sh!tBoxHonda's Avatar
why? I heard aem is trash and still is. I've only had one but it felt like an ebay kit worth 30$ aem uego series x
Old Nov 28, 2021 | 05:20 PM
NVturbo's Avatar
O.G. triple O.G.
install error most likely. Some people tend to half-*** a simple installation.
Old Nov 28, 2021 | 05:45 PM
Bottlefedz28's Avatar
Loved
Innovate uses the same Bosch lsu 4.9 sensor as aem or almost any other wide and.I have had multiple innovate lc2’s on multiple vehicles and never had an issue. I’d be willing to bet 98% of the complaints you see about innovates are from people not wiring exactly to the instructions with special attention paid to the ground circuit. Only other wideband I’d recommend is the ballenger motor sports that uses the ntk sensor, but you’re not going to run to the parts store to get that sensor. It is a superior sensor though. Another thing to make sure the sensor lives is to make sure it is installed above the center line of the pipe, the higher the better
Edit, just realized this thread was from 2019. Atleast I’m not the one who brought it back
Old Jun 22, 2022 | 05:27 PM
turns out aem is just trash. Installed a couple more innovate no problem and all the other aem guys are having problems with the gauges going bad
Old Jun 23, 2022 | 09:58 AM
spAdam's Avatar
Loved
Community Favorite
PLX and done.
DC2-ProdUcTiOnS
May 13, 2009 07:00 PM
Homotor
Nov 20, 2006 06:42 PM
Nextelbuddy
Dec 10, 2003 09:10 PM
Project91CRX
11
Oct 6, 2003 11:41 AM
