- neptune ?'s
- s300 shift light
- I need a wideband and S300 refresher
- aem ems 30-1050
- Need help with Injectors
- "hondata s300 issue"
- 93 civic dx y7 swap auto
- turbo gsr full cuts off
- Can't Richen up with Crome
- Mini me
- Weird Problem
- Which B series should i go?
- s300 tps question
- converting to coil on plug setup
- TUNERS
- burning a chip for a p13 ecu?
- AEM FIC 30-1911
- What is a good mail order tune for hondas?
- Aem stat sync issue?
- lsv and questions .
- Help! MTX-L Innovate wideband
- Bad ECU?
- Let's Talk Injectors...
- help with lsvtec base map
- PM5 ECU, 88 Civic DX
- NepTune RTP Knock Board
- hard butterfly
- JDM 98spec ITR Conversion Harness question
- Cold Idle Issues (93 ex d16z6)
- Hondata S100 problem...
- ecu question and harness verification
- tiny cuts on b16a2 with EFI Ecu
- setting up a base tune
- Tuning time estimate
- apex vtec controler help
- Crome Mappers
- who/how burn gold bins using pro
- ECU Connection Location?
- Hondata S300 Question
- Opinions on Wireless S300 Idea
- Do SST reprogrammable chips go bad?
- Chipped ecu re-install
- vtech system failure reading ?
- 1989 honda civic hatch dx overheating
- Neptune - mapping
- hondata s300 with tablet
- b16 issue
- 92 Honda civic Radiator Fan problems
- ELM327/Android OBD2 reader as piggyback on ECU?
- ???Will this set up NEED dyno tuning???
- OBD1 data logging via Andriod
- ECU shut car off?
- Wiring Diagram
- Need help; completely lost.
- how can i tell if i have chrome
- Data Logging issues
- 1995 Integra
- hondata s300 tune issue
- is 89mm crank (b20/ls) more sensitive to lean mixture and detonation?
- EK GSR Swapped wont read code
- delphi injector dead times
- Need advice on crome map.
- Chip or Tune
- hondata s300 removal question
- chipped p75 or p06?
- what oil do u use after braking in your motor
- Chipped or and tuned help
- good chipped ecu for temporary use to get to the dyno
- spark plug reading and ignition timing
- Large Gaps on Fuel Table
- Lost with 450cc dsm blue top
- crome boost option MAP parameters
- Help with 11.5:1 GSR timing tables.
- two stock ecu's
- Good maps to start for AEM FIC
- obd2a lsvtec
- is this a converted vtec board p75
- Help - C60 popped
- Car Idling too way too high or normal. Innovate Wideband and S300
- Error 1457
- Help - Hondata Launch Control w/o Speedo
- F10 in Crome?
- First Time Tuner: Generate my own basemap or purchase one?
- Car only starts with starter fluid
- Hondata K-Pro ... Part Throttle Tuning
- Stupid question on Neptune...
- Looking to upgrade?
- hondata s300
- D15B7 Emissions
- Direct Serial Logging with MTX-L in Neptune
- GSR swap obd1 code4
- Built h22 with afr problems?
- Fuel pump dead?
- pros/cons of plug types?
- B16A SiR-II / ECU
- Hondata S300 being burnt onto chips???
- New IM causing problems! Help!
- Acceptable method for tuning high cam fuel map
- 89 accord carb questions
- d16y8 won't rev past 5500 rpm
- basemap fuel trim adjustment where to start
- p28-a51 ecu
- Upgrading Cams/IM
- 1999 civic si shaking
- code 7 tps cel HELP.
- NYS OBD2 (non K series) inspection/emissions/tuning discussion
- crome pro "enhancements" is unclickable. and cells wont datalog
- LA area tuners?
- b20b with boltons anyone share neptune cal?
- crome pro goes crazy when data logging
- 2000 civic engine light
- totally unreal crome pro problems never seen anything like this
- FlashPro part numbers??
- Need timing tuning techniques
- Need mechanic in southern Maryland
- Check engine code p0420
- Help plz, I have a time sensitive question!
- QUick Hondata S300 question
- Best way to burn multiple chips and datalog. Read so much stuff. What's true
- s300 wont switch over to high cam maps
- AEM ecu in 99 integra reads 100% throttle all the time. Need help ASAP.
- issues using LC-1 as narrowband with crome, signal issue or tune?
- 99 EJ help
- RF interference freezes logs.. moving ecu 6-8 inches it logs ok?
- Widebands
- which scan tool would you recommend
- Will this ECU still data log? Or should I sell for a new one?
- 93 honda del sol type r swap problem, won't rev past 2.5 rpms
- S300 V2 acting up ??
- Check Out My Basemap
- Hondata S300 Override Radiator Fan Control
- ECU options for JDM swap
- If anyone is looking for a basemap or tune check out this guy...
- Verify my research
- NEW: Hondata FlashPro Support for Acura RDX
- Looking for a map a bit tuned for a stock D16Z9
- Help please! Car keep cutting off after hondata update
- Can't log the A/F ratio with Crome
- using d10 for wideband datalog
- advanceAny recommended FL tuners.
- help ......
- AEM EMS 1040 How to setup IAB's
- 270 base injectors in Type S with Kpro
- reading the porcelain on your plugs
- transferring my tune?
- Limp mode from cat delete?
- AEMpro cals to AEMtuner conversion
- h22 headache s300
- wiring up AEM wideband into 96 integra
- s300 knock detection
- whats the different from a d15b1 vs d15b7
- b18b head on b18c questions
- Help with walbro 450 install.
- URGENT! Stranded: fuse problem
- Hondata S300 Boost control problem
- Considering picking up a MTX-L
- Megasquirt for COP J series motor
- wiring up switches(hondata s300)
- rich gsr with bad mpg
- Serial Logging Anyone do it?
- how can i be at 2"Hg when wide open
- Is anyone using Crome Pro on a Windows 8 OS?
- B16A2 P2T A11 to A12
- Crome Pro license on a crashed laptop?
- Need advice/tips for new stock Civic.
- How do you get rid of the check engine?
- AEM1040 EPM M&W timing drifts
- No injector signal after chipping ecu (car wont start)
- part throttle tuning question
- Need better SRI Basemap - Flashpro/08 Si
- D16z6 problems
- crome 1.6.8?
- h22 or b20
- idle problem
- 1000cc ID's, hot start problem
- Need valve sequence for '95 Vtech 16 single overhead
- Need "more than 2 posts," to become member, so askin ?,s
- Partial Rebuild, why duz it run like this?!
- Throttle cable question for ex ls swap
- Adjusting fuel pump prime durration on S300?
- Immobilizer
- Question About ELM with 1997 civic
- 94 accord F-22 motor looking for swap
- 94 accord burning computers
- 2010 TSX won’t start after accident
- Hondata S300: Lambda overlay staying blank, won't log AFR values
- I need help please
- .ncl File Needed for Datalogging with Neptune?
- Using my S300, few noob questions
- looking for tuner
- S300 Tuning Questions
- Always rich with Crome??
- oil pump b20b
- Turbo B series throwing code 02 (oxygen sensor B?) after a pull??
- Tru Boost Solenoid
- i need help plzz
- 2000 Civic Si Hard Start Issues
- What is Code In wiring diagram
- Guru's - Help me choose - Neptune vs S300 V2
- Gizzmo Launch Control Interface 2
- h23 timing issues!!!
- Crome's GM 3-bar MAP voltage appears wrong, delivering bad readings
- Neptune turbo ls/vtec Hiccup during vtec crossover.
- 3rd Gen Civic HB DX
- Swap or not
- Air / Fuel Issues
- Bad MPG/Acceleration!! Help Please....Sick and Tired
- dyno tune vs track tune
- ctr base map
- 99 Civic dx p1457
- Need help finding TDC for gsr obd1
- obd1 GSR, need help with correct timing.
- D16z6 vtec head, y8 bottom end.
- HELP!!! Weird problem! 96 civic ECU
- b20b running lean
- Reputable Hondata (Honda builder and tuner) in Midwest?
- Ecu chip question
- ecu chip?
- The philosophy of how we retard ignition timing in boost: to what end?
- OBD0 stock BIN files
- LC-1 With Red DB Gauge Install Help!
- JDM B16A W/Hondata S300 limp mode no CEL
- how to chip b20b?
- Vetch
- b16a 1000cc Precision injectors calibrations
- No idea what is going on with my f22b1... VTEC
- Fluctuating idol b16a
- P28 throwing CEL but disappears when ignition is turned off.
- getting the most out of my d16z6
- noticeable increase
- oil light stays on
- S100 vs. S300
- Redline will not change with Crome.
- Redlines when started HELP!!!
- mtx-l wideband offsets and datalogging question
- B18b1 start up problem
- neptune rtp erases tune every key off
- Fuel Pressure Regulator?!? Stock with walbro 255?
- ECU tune Demon
- Aem EMS Starter Kickback
- questions about zeitronix zt-2 vs. zt-3
- 1998 civic idles, but floods out. Help!
- Schematic of ECU PCB
- How to install oil pressure gauge?
- NEED HELP ATTEMPTING TO TUNE!!! S300V2
- NEW: Hondata FlashPro Support for International Accords
- Hondata headache! Insight much appreciated!
- Noob question here
- Hondata K-Pro question
- b16a2 idle help
