- crome tuners in sacramento ca area (need a tune)
- gsr misfiring. somone help!!
- aem ems 30-1050 99-00 civic
- fuel choices...
- ecu circuit layout
- What dyno do you use
- air fuel mapping
- Need a fuel map (erl built b18c)
- Wideband install ?
- Ignition Base timing with cam gears
- Ls/Vtec Help!!! Please help me out
- question about ecu for my engine d15b e-vtec 98
- Tuning ignition timing
- how hard is it to chip a ecu?
- JDM B18c1 - Down on power but running perfectly smooth - Ideas?
- OBD1 P28/P30 in a auto tranny Prelude
- Crome ECU Problems
- Vref pin????
- ECU SOCKETED PROBLEM , Please HELP ME OUT.
- GSR Turbo AEM Map needed
- BatteryFuse Blowing B20 Engine+B18C
- Ostrich 2.0 USB Real Time ECM Emulator
- P28 ECU Question (Mini ME)
- Any local street tuners?
- emanage support tool needed asap
- freelog and GM 3 bar map help
- Ectune info
- emmisions!
- new to neptune, need a good coach
- Cn2 obd2
- H22A in 96 accord EGR check light
- Accel DFI?
- Ecu
- CEL on but no codes in hondata s300
- Phearable
- water methanol injection
- i need some help please.
- wideband wiring ?
- Innovate LC-1 and Moates O Meter...
- how much gain?
- Newbie Tune Up on 96 accord lx
- ls vtec swap help
- vtec solenoid bad or sensor!?
- noob need info about tune
- OBD0 tuning ?'s
- Need Help pls - Vss for 95 delsol
- I need a little help
- Machine Shop
- 1.5 VTEC tuning
- b16a2 being run by an unchipped P08??
- obd 0 vtec or obd 1 vtec?
- Super air flow converter questions
- converting obd1 to obd2b
- Cel after ecu chipped
- halp failed smog... someone decode failure
- Don't no know much about ecu
- worth the upgrade? S200 to S300
- apexi vafc2! need serious help ASAP!!!
- Slowmotion motorsports new shop & video
- chiped ecu for d16z6 racecar
- Crome and starting a new engine for the first time
- Smog failure
- Anybody using megasquirt?
- obd0-obd1 jumper question
- bad ecu
- question about gas
- problem with crome and vista?
- Greddy E-manage?
- Any reliable tuners in Colorado/Wyoming?
- On the cheap
- Problems with my GT3582R + Tial 44 !!!
- New to honda tuning, but not to performance tuning.
- Acura TSX ECU in a Euro Honda Accord???
- P72 adequate for B20vtec breakin?
- Problems starting in the cold...
- Apexi safc neo....?
- S300 datalogger
- Before /After Ignition Map D16Y7 critic please.
- What could be the problem?
- burned up computer?
- greddy e-manage blue question
- AEM EMS Connects but all values go everywhere
- recoment a tuner/reburn a chip?
- crank sensor? b16a2
- EcTune vs AEM ems
- hondata
- HELP, Battery Voltage Drops Under WOT
- Just had car tune on s200 and have datalogger question
- vafc ?
- What hondata setup do I need??
- Checking O2 Sensor w/Multimeter?
- ECU problem
- hondata s100 retune in cali???
- Cold start question- Do I have too much fuel or not enough?
- Neptune + Wideband question
- gsr with bolt ons and skunk2 im. what base map? P72 or P73 map?
- AEM wideband EUGO air fuel gauge issue
- b20b obd2a to obd1 conversion....need help!!
- Poor Man's Type-R : HELP with ECU!
- For sale
- failed my emissions because of carbon monoxide how to fix?
- s300 boost control and other options
- Problem in AEM EMS - Engine load stuck on 35psi
- 97 prelude obd2 to obd1
- Saturated Vs Peak And Hold Injectors
- total noob stupid question....have to start somewhere
- Hondata s300 vs. ECTune
- shops to tune crome in ohio
- base maps.
- Tuner in/around louisville KY
- nitrous through hondata
- ITB vs. ECU tuning, vacuum problems etc.
- Tune?
- Activating Secondary Maps on eCtune
- AEM wideband messed up? Help.
- Closed Loop Operation
- H22 tuning question
- Where do I find the map sensor?
- Street tune?
- Fuel Pump, should I upgrade for my setup
- DIY Tuners!
- EMS EPM and ignition box Question
- Engine managemant????
- What are good chips, "unichip" type devices or tuner for a J30 1999 Accord Coupe V6.
- Any risk in tuning just one cylinder with rest off?
- new manifold new tune???
- VAFC jumpin to crome..
- Is a waterpump mandatory for ls v-tec conversion?
- Question about setting timing with s300.
- alternator help plz!
- Spark Plug Reading Pictures
- Stock o2 sensor with S200
- 3 bar map sensor wiring
- B20B tuning
- AFR on bolt on 06-09 Si?
- Injector / fuelling issue?
- ...what are some good fuel injectors...
- For sale Brand New Unlocked Nokia N97 for $300
- eCtune website?
- can i accomplish this with neptune?
- Is this p05 ecu set up for Vtec?
- Need Haltech experts HELP PLEASE
- eCtune VS Crome
- a few noob tuning ?'s
- How rich is too rich?
- how to install a Buddy Club V-CON VTEC Controller
- OBD0 TO OBD1, full convertion
- b16 swap help!
- obd2b modification question
- Help w/ p75 hondata s200 back to stock
- tuning question
- How to read and use turbo compressor maps
- do vtec controllers work with ivtec
- 94' Body 97' Engine
- ECU help please :/
- obd 2 or obd 1
- Aem epm....
- wiring up a o2 sensor simulator
- Stock 92-95 H22A Turbo basemap please
- pin d14 on ecu?
- LC-1 Wideband, Moates Burn2, Hulog, Uberdata/crome/freelog? Newb.
- hondata s300 problems w/ live datalogging
- Yeah it's another ECU question...
- please help with my sparkplug gapping!
- Hondata ECU with built on OBD2 connector
- chipped p75 check engine light problem
- VAFC2 wiring help on obd1 harness
- just got a chipped ecu
- ECU's that dont prime the fuel pump
- Type R Vavles in a b16 head?
- p75 chipping
- DA needs a trans plant
- Connecting AEM wideband to S300
- 00 R W/ Neptune and a CYP CEL, Help
- neptune question
- Detonation check list
- B16 Idle Vacuum Readings?
- newbie to ECU tuning on F20B
- hondata s300 Display function
- P28 IACV Driver
- OBD2 Tuning Options -- Need Some input
- which ecu would be better p06 or p28
- need help p28 ecu h22 question
- how to install 99 b16 piston in gsr block
- aem ems 30-1010 and greddy profect spec b II
- Stand alone vs wide band
- P72 OBD1 IAB rewiring issues
- hondata and greddy profec
- p28 a52 ecu question
- chipped ecu vs ems?
- which is for me?
- S300: Anyone have an H22 stock basemap?
- Anyone Have These Two Books???
- Questions
- Only one cyln running lean please help...
- running a chipped ecu without a chip?
- Hondata vs Microtech Need help
- Difference between the P30 and P28
- Crx swap turning over but not starting
- crome/injector size/fuel multiplier
- Questions about tuning
- aem uego ?
- ??? about ECU
- aem EMS 1040 COP tach issues
- Civic 1988 DX ignition problems
- 1988 civic DX wont start
- wideband useable with stock ECU?
- p13 ecu
- 1990 crx zc swap,turbo obd0,map sensor????? ect........
- missing the sensor in the vtec solenoid
- Any easy way to convert Hondata map to run in crome pro? Help asap!!
- ignition timing??
- Crome burner
- Guesstimation On whp
- Boost controler?
- Hondata s300?? How to use?
- crome chipped p30 not reading the map?
- ***ecu help***
- DATALOG Switch hook up?
- base map
- EJ Full Throttle Wiring...
- Sadm vtec ecu
- $450 good price on neptune+tune
- quick tuning question
- got a question
- jus got cam gears
- what do these numbers mean..
- gsr ecu into eg-ej
- vtec not kicking in right
- What computer came stock in a 1994 Civic EX?
- good nitrous air fuel ratio
- BIG Thanks to John Vega @ Phearable
- rebuilding my 91 b18 , help?
- b18a1 (obd0) in a 95 civic (obd1)
- OBD-0 to OBD-1 conversion
- More tuning questions- Cutouts and dual maps?
- question about buying a chip?
- Ep3 shot out spark plug
- crome
- TSI black box question
- Tuning salutions
- Crome Base map?
- Need help ???
- Moates Hulog Install Question
- Tuning without an emulator?
- help with msd
