PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Hurricane Irene stalls my car
  2. Is an S300 that much better than an S200???
  3. Need help with lopey idle adjustment, want it constant!
  4. Upcoming MOTEC/AEM - EFI Unversity Classes in the NY/NJ/CT/PA Area
  5. b18c1 with p2t ecu.
  6. ecu tuning
  7. I'm going to install a AEM digital Water temp gauge
  8. D16Z6 rebuild question!
  9. b18b1 to b20b swap problems (not bad) please help!
  10. Issues with Rywire Harness in EM1 *please help*
  11. help getting 2.5 motorola map sensor to work?
  12. Easy RTP
  13. Need S300 Calibration for Startup
  14. P30-900 Capasitor change..
  15. aem v2 ems k series integra breakin up
  16. throttle body cleaning need advice
  17. Hondata s200 HELP!!!!
  18. idle surging problem
  19. crome gold tune
  20. Tuning my JDM B18C
  21. LS/Vtec in a VW Manx Buggy.....WIRE HELP!
  22. Tuning College?
  23. Street cam tuning
  24. Would a P2P ECU work with a D16Y7?
  25. D-16
  26. how to get tach signal from s200 ecu
  27. best option
  28. Hondata s200 & Uberdata
  29. What chip can I use?
  30. were to buy stock ecu
  31. help with teg
  32. B&M Fuel pressure gauge broken?
  33. is my s200 broken (missing clip to far right)
  34. 99 si with no power after being warmed up
  35. Ignitor ICM delete remove, removal, bypass
  36. make tunerpro definition files for obd1/obd2
  37. D16 turbo basemap
  38. 92 hatch with d15b turbo questions
  39. What management should I get for my 99 SI Turbo project?
  40. Neptune Questions Datalogging/Hardware
  41. Is my ITR worth tuning?
  42. bluetooth units for obd1 civic ecu ectune demon tunerview
  43. p72 q31 transistor burnt i need different answers
  44. Crome 1.6.2 BUG????????
  45. Need some help with hp and tuning
  46. P73 ecu ?
  47. Bigger injector, how do you adjust fuel in s300?
  48. pte 1600cc?
  49. Honda Datalog for Android
  50. b18c-r Eg running lean (dyno pic)
  51. help tuning 92 civic h2b DX
  52. wanna buy a chipped ecu for my d16y8
  53. GRINDEING NOISE HELP NEEDED PLEASE!!!!
  54. how to make IAB via VTEC obd1 ecu HONDA
  55. Help me identify this (possible wideband)
  56. b18c1 head on b18b1
  57. GSR fuel but no spark
  58. S200 tuing
  59. Tech-questions
  60. Measureing EGT on headers
  61. Active development/deconstruction of ECUs and programs
  62. ECT 211 on a hot day
  63. untuned Turbo GSR
  64. inlet mainfold, which one ????
  65. rev issue
  66. Car running rich after a while ( Hondata s300)
  67. GM 3 Bar issue
  68. gasket blown?
  69. no afr in dl with crome pro
  70. MAP dropping after 7500
  71. Vtec A/F ratio
  72. S300, is it better to tune using a wideband or tailpipe?
  73. Crome - From the beginning
  74. Using Knock Listening Devices
  75. hondata s100 or chrome
  76. Standalone ECU and OEM Dash sensors/outputs
  77. GM ICM for controlling a MSD coil?
  78. Idle duty cycle and basemap. B18c and precision 1000s
  79. reading s100 chip
  80. Tuner advice high boost timing Question
  81. LTI framework? PID control?
  82. hondata update problem help
  83. what tuning system is right for me?
  84. having rough idle need help plz.
  85. Hondata ECU turning off shortly after turning ignition on
  86. P06 Vtec Conversion?
  87. deatschwerks injectors
  88. air fuel gauge
  89. Helping a Neighbor - 2003 Acura TL 3.2 VTEC
  90. Please help read these plugs? (Caution: VQ35DE content inside…)
  91. When changing engine hoses and cables, do they need purged?
  92. aem 5bar map sensor, maybe broken? please help!!!!!
  93. Obd2 H22 Cam Gear tuning----Myth debunked?
  94. TPS issues in smanager
  95. B series swap runing like Sh*t
  96. aem uego and crome afr
  97. 98 hx oxygen sensor question
  98. LS/vtec basemap vs. PR4 basemap
  99. AEM wideband sensor, replacing to a new lsu4
  100. watching datalogs crome pro
  101. Anyone Here Familiar With The Twin Loop Exhausts?
  102. OEM H22 Low cam/Low Fuel tune
  103. Power Chips?
  104. msd ignition
  105. Turbo AFR
  106. DIY CUSTOM ENGINE HARNESS NEED HELP
  107. Help with RyWire Milspec Harness
  108. Ecu Suggestion, P73
  109. bouncy idle when luke warm only? please help
  110. Serial to USB that works with AEM EMS (need help choosing)
  111. civic turbo going rich afr for no reason!
  112. Dyno sheet help
  113. Boost solenoid setup suggestions...
  114. Traces On ECU Modified?
  115. s200 help
  116. Obd1 harness obd2b dizzy.. Where to get tach signal
  117. Narrow band oxygen sensor heater control
  118. New Motor- Couple Tuning Questions
  119. can this ecu run like stock
  120. chrome launch control will not work!!?
  121. Neptune closed loop with MTX-L wideband sensor
  122. car running lean what could it be
  123. Troubleshooting Solid CEL chiped p28
  124. S300 - Motorolla 2.5 bar w/ Stock Gsr Basemap?
  125. Tuning with Methanol
  126. Demon USB Cable Question ............and Fusebox location question
  127. crome 1.6 disables the old version?
  128. Integra LS B18A - Megasquirt, AEM, others? What's best?
  129. 1996 Integra Turbo B18C1 & AEM EMS Install
  130. Chipped p28 basemap suggestions?
  131. Looking for Tuner in WI
  132. how to hook up data logging cable in a P28 ecu.
  133. hondata dead times for rc 750
  134. Name these Injectors!!
  135. s300 default menu for B.B.G.?
  136. Just a reminder when buying used...
  137. Stock 240cc injectors safe on a mild allmotor GSR?
  138. I don't want to replace my cat with a test pipe. can I weld a bung in the...
  139. what ecu pin do i run my aem wideband to kpro
  140. car keeps getting rich after tuning numerous times
  141. Idle Issues? ECU The Culprit?
  142. B18c1 smoking issues
  143. Any one have a crome bin for a B18C4?
  144. 88 CRX Project: Help With Headers!
  145. Engine wont start
  146. B18c Apexi FC - 3 bar map sensor?
  147. Need help finding a good tuner in DENVER!
  148. Ps/alt Mounts..
  149. alternator control
  150. AC Vtec controller
  151. 2000 integra gsr spurting after like 2500 when accelerating slowly
  152. s300 fuel enrichissement lag
  153. itr with a .48. Can this be tuned for street
  154. 89 crx having promblems please help
  155. knock at start up and shutting down plz help !!!
  156. B18a1 Blowing smoke and gets cut out. Help!
  157. Tps problem with emange help
  158. 1992 civiv cx tuning
  159. FL: Calling all street tune GODS!!
  160. Injector Scaling in Chrome
  161. spark plugs for del sol?
  162. Obd1 Auto to Manual
  163. Need d series turbo e85 base map crome
  164. What are my ECU options in MN?
  165. Misfire at idle need another brain
  166. ECU Tuners for 2006-2011 civic (not Si)
  167. Possible file name extensions for tuning maps? (new download directory)
  168. ECU CODE READING
  169. need basemap for s300
  170. Pilot ECU's: Swappable within year-to-year?
  171. Need Help - AEM ems on J32 - custom harnes
  172. rywire.coms full aem cop kit
  173. Spark plug hole full of oil!! Help
  174. vtec wiring
  175. fuel cut and cel, cant pull codes obd1 need help
  176. setting 2 step in crome gold base
  177. question regarding a few tuning concerns
  178. 4 seperate probes and egt meters for each cylinder for tuning?
  179. How to Update to Crome 1.6 without losing your PRO Registration
  180. Setting up injector dead times s300
  181. S300 P28 burns up on the way home. Looking for input and/or reasons why
  182. how much hp do you pick up from adding timing
  183. box in the back of b series engines...
  184. Compton Rob is the man
  185. EuroR compatibility questions
  186. anyone here run megasquirt?
  187. P30 problem, fuel pump wont start, pls help! :)
  188. S300: new 550cc, do i need to manually scale down all fuel?
  189. VAFC or SAFC??Which one is better for my Engine??
  190. Grounding and EMI
  191. crome1.6+freelog1.0.93 errors
  192. Can a H22 Engine Bolt on to my Automatic 2000 Honda Accord?
  193. WHO USES DET-CANS??!?!
  194. Missfire issues, stumped...
  195. getting tune for the first time, have ???s
  196. Tuning free revving/ 2 step portion of map??
  197. Barrow OBD1 ecu?
  198. Neptune and non-resistor plugs.........
  199. b18c1 v-tec solenoid help......
  200. AEM Digital boost gauge install
  201. LC-1 vs MTX-L question
  202. Adjusting Timing
  203. ELD code 20 - CROME/P28 2000 Si
  204. new to management...some questions about a chipped p28 with s100
  205. e85+id2000cc+s300 small problem
  206. Freelog+AEM UEGO Inquiry
  207. LC-1: Full lean, then LED off, then full rich
  208. chip "forgot" tune after dead battery??
  209. lc1 need some help
  210. Ecu programming question
  211. Old hondata s2b
  212. Just how much should a tune cost?
  213. SEM terminal block
  214. del sol fluids?
  215. 08 Si, Flashpro, RH/Exhaust/injen CAI
  216. Engine Swap Help
  217. what ecu for b18c?
  218. plugs for boost?
  219. HELP!!
  220. Demon or ecu damage to pin j1?
  221. AEM EMS question... Fitment question
  222. Thinking I may need a re-tune
  223. 10:5cr to 8:5 turbo engine
  224. K20a2 Rcrew cam injector help!! Please
  225. S2K AEM EMS 1052 and adding AEM UEGO
  226. ecu help
  227. basemap for b16a with CTR pistons? (hondata)
  228. Benifits Vs. Cost Of Going C.O.P.
  229. Software for E Manage
  230. Failure in my 96 civic w/ swap b18c5
  231. Neptune RTP questions..
  232. problems with s300 over crome
  233. Phearable chips for JDM F20B DOHC Motor
  234. Hondata S300 Calibrations
  235. Strange ECU/ Chip Problem. HELP!!
  236. LS/VTEC basemap
  237. Profec B solenoid broke...HELP PLEASE
  238. should ECU be hot when car is off????
  239. Lean idle, fouled plugs
  240. Having trouble keeping my 91 civic dx running
  241. Two ECUs, 6 different CELs!
  242. s300 syncing time doesnt seem to be right
  243. OBD code 2279
  244. Couple tuning questions
  245. Couple of questions in neptune
  246. AEM EMS and Coolant temps?
  247. what engine management to use? k24 into cd7 accord obd1
  248. Hondata ecu problem
  249. Need help with Crome P28 H22A LogWorks vtec crossover problem
  250. B16B Basemap on a B16A
