Do I need a tune for a rebuilt engine?
Old Sep 9, 2019 | 07:36 PM
Brembomaster's Avatar
Default Do I need a tune for a rebuilt engine?
Recently, I have rebuilt a b18c engine and run with power fc.
I had tuned the engine before rebuilt. but at the time I tuned for it , the engine not in perfect condition, just 150psi compression across 4 cylinder.
I rebuilt the engine with 1mm+ oversize piston, same camshaft as before. In this situation , Do I need to retune?
For now, the engine with no issue and I dun have to air/fuel ratio to monitor. So, I dont know does the map fit for my rebuilt engine.
Or any way to know the map is good or bad for my engine.
Thanks.
Old Sep 9, 2019 | 09:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Do I need a tune for a rebuilt engine?
Yes, you need a re-tune.
Old Sep 9, 2019 | 09:07 PM
For now, the engine with no issue and I dun have to air/fuel ratio to monitor. So, I dont is that map fit for my rebuilt engine.
Thanks.
Old Sep 10, 2019 | 10:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If the tune was based on a weakened/compromised engine, a healthy engine will make more power... and this means that your current tune will be lean. Lean is dangerous. Get a re-tune.
oldspriteguy
Classic Hondas
Nov 28, 2013 04:17 AM
xbladr
Northeast (Sales)
Aug 1, 2005 07:58 PM
